F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Amplifiers
Thread Tools Display Modes
Old 10-10-2009, 12:59 PM
LOC Line output converter install with pics
I've been searching for a few days and didn't really see what I wanted visually, so I took some install pics.
This is what you need (or something like it) to install an amp to factory system. This LOC converts high level to low level (rca's)
If you look at the pics, you cut the factory speaker wires (or buy a harness, and a reverse harness to avoid cutting factory stuff) and route them into this LOC. Got mine at Crutchfield for $20.
Then you will have to run RCA's to the back, and then speaker wire back to the front to the other side of the speaker wires that you cut to send the amplified signal out to the speakers.
I'm sure there are many other ways to do this. Turned out good, sounds awesome.
Here is a copied post of the speaker wire colors. Mine is an 07 SCREW LAriat.
My Remote wire was the Green with yellow, in one of the pics. If trying to find switched power, be sure to have the door open when you do it.
Enjoy-
Radio Ignition pink/black or lt. green/yellow + radio harness
LF Speaker +/- orange/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- white/lt. grn - dk. green/org +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
[IMG]http://i47.photobucket.com/albums/f156/dtrain475/IMG_1250.jpg[/IMG
Old 10-10-2009, 02:00 PM
Vehicle: 2002 Ford F150 FX4
nicely done. i have always hated those things because i always got feedback after installation.
2002 F150 FX4. Black two tone. Extended cab.
-SI/DO flowmaster catback
-AFE cold air
-EDGE Attitude. Level 2 Custom.
-Headmaster Shorties. One cat for each side.
-305/70R16 ProComp Xterrains-16" American Racing rims.
Old 10-10-2009, 03:31 PM
Turned out good, no noise. I was kind of expecting it. This LOC has its own ground, maybe that helped.
Old 11-03-2009, 06:06 PM
Vehicle: 2005 FORD F-150
I made up a "T" harness to make everything plug-n-play. Everything soldered, no butt connectors.Even the speaker wires coming back from amp plug into this harness and feed the factory loom.
Old 11-04-2009, 12:42 PM
Ok... I am little confused. I have never messed with LOC's or anything. I am debating on getting a new HU just so I don't have to. But then you posted this. Do you mind getting a little more detailed?
Why do you have 2 sets of rca's? I see that it says R&L rear and R&L front. But where do those connect? I assume to the amp which has 2 rca connections correct?
Also, the purpose of the LOC is so that you can keep the stock HU and the stock speaker wiring correct?
2008 Dark Blue Pearl XL F-150
Tint/Chrome Handles/16g Ipod Touch/Rockford PT-1 Tweets
2006 Mustang w/Pony Package
Tint/Clear side markers/Clear corners
Old 11-04-2009, 11:00 PM
Most 4 channel amps will have 4 (rca)ch inputs, therefore using all 4 rca runs from a LOC. It will retain fading and balance controls accurately.
Now if using a 2 ch amp or amp with 2 ch inputs then 4 ch LOC would not needed or use all 4 rca's.
Depends on setup, maybe 4 ch amp with 2 for mid/high and other 2 for sub, then fade controls would be lost.
If you're only adding amp for sub, and powering doors with HU, then the LOC's that are pictured provide "pass-thru" for that setup as well.
In my case, I'm using 6 ch amp, 4 ch for mid/high, 2(bridged) for sub. The fade control on radio is used by the amp the blend levels between sub and door speakers.
Using factory wiring back to door speakers is easiest, but not as optimum as using quality speaker wire. I don't worry about it because I'm using stock HU. If I wanted better quality sound, I'd start with new HU first.
Old 11-05-2009, 10:55 AM
Ok I think I understand. Let me explain what I want to do and tell me if I am doing it right:
I just bought Polk db 651's for the front doors. I want to buy 2 more 5x7's for the back.
Then I want to run a 4 ch amp just for the door speakers. I would like to put in my own speaker wire.
I do plan on running a seperate amp for a sub later.
So if I run my own speaker wire then how will the LOC wiring work out? I want to keep the stock HU for security purposes.
Sorry for the noob questions!
Old 11-05-2009, 10:57 AM
Should the LOC wiring still stay the same as this?
Then just run my speaker wire to my amp?
Old 11-05-2009, 12:16 PM
Vehicle: 2001 Ford F150
You tap into the speaker wire at the headunit to get signal for the LOC. The LOC gives you RCA outputs that you run to your 4 channel. You run your speaker wire from your 4 channel to your speakers.
- 285/70/17 BFG ATKO - AVIC N3 - Infinity Kappa - Infinity 475A - Magnaflow SIDO -
- Magnaflow Hiflow's - Volant CAI - Lightning Heads - LED Corners - Security by Viper -
MECP Certified Geek Squad Autotech
CEA# 174955
Give a n00b the answer he will be learn for a day; show him the search button, he will learn for life.
Old 11-05-2009, 01:34 PM
Quote:
Ok got it.
"If you look at the pics, you cut the factory speaker wires (or buy a harness, and a reverse harness to avoid cutting factory stuff) and route them into this LOC. Got mine at Crutchfield for $20."
So I can get a harness from Crutchfield so i don't have to cutt the wires?
Old 11-05-2009, 02:13 PM
You've got it. An install harness, and a reverse harness. Reverse harness will duplicate the factory one in the dash. Just pass thru all the power and control circuits between the connectors. Then the speaker wires on the reverse harness side (the one that actually plugs into HU) will go to the LOC.
Your speaker wires from amp have nothing to do with this conversion since you will be running your own to the speakers (bypassing going back into dash harness).
Old 11-06-2009, 11:42 AM
Mach1 69: when I start to do this do you mind if I shoot you a pm if I have any questions. I got the speakers on the way but I haven't decided on an amp yet. Thanks.
Old 11-08-2009, 11:34 AM
does anyone have the part # for both harness?..
07 hd,eibach 2/3 ,soon to be boosted.
Old 11-08-2009, 04:20 PM
Some amps have speaker level inputs which is essentially a built in LOC. You can also have less noise if you run speaker level to the amp and mount your LOC there.
Old 11-08-2009, 04:31 PM
Quote:
ok so you are saying that you don't need a LOC if you have speaker level inputs or do you need both?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
