tires for stock rims
Your tires are 16x7".
Go to
http://www.tirerack.com/tires/Spec.j...del=LTX+M%2FS.
It will give you the specs on different tire sizes including rim sizes for the Michelin LTX MS. You can also pick other tires and do the same thing.
Go to
I have the same truck as you. It depends on what you want to to with your truck. I am concerned with mud and snow so I went with a taller tire that is thinner than the stock 255's. I put on 235/85-16s. I love them, they look great and really cut through the mud. I chose to go up in height (from 30" to 31.6") so that they'd be less likely to spin. It makes the truck a little slower off the line and the speedo is 5mph slow at 60mph but I don't mind either of those things. Hope this helps.
