need some help....
Old Jul 20, 2011 | 07:21 PM
dixiefishing's Avatar
need some help....
Quick question - My 04 f150 has leveling kit and Ive been running 325/60 and 295/70 18's for a while. It's time to buy new tires and I really want to run Nitto 325/65/18 Terragrapplers - I know they will fit except for rubbing the upper control arm - I need to get spacers for the wheels. My question is what size spacer should I get - and does anyone know where I can find them for a good price?
Thanks!
Old Jul 21, 2011 | 06:02 PM
MossyOak3006's Avatar
1/4" spacer should be enough, but I'm not for sure on that
Old Jul 21, 2011 | 06:25 PM
hardrock3742's Avatar
Ive heard from most people that spacers are a bad thing.
Old Jul 21, 2011 | 07:47 PM
I have too. I've never used them, and I don't know anybody that has. I've heard they crack sometimes which leaves your tire loose and wobbly while your going down the road
Old Jul 21, 2011 | 09:00 PM
mdhawkin's Avatar
A 1/4 inch spacer is not that bad, big key is to make your you get enough turns/threads on your lug nuts. Ideally its always better to avoid them if possible.
Just curious the overall height difference between the 60 and 65 is about 1 inch, will that .5 of an inch make a difference since they are the same width as what you have ran before.
Old Jul 22, 2011 | 07:58 AM
The 65's touch the UCA the 60's are about 1/8 inch away from it. So I figure with a spacer - even just a 1/4 inch one - that will be enough to keep the tire off the UCA while riding.
Thanks to everyone for the feedback - I will let ya know what I decide to go with once I make the decision.
Old Jul 22, 2011 | 10:35 AM
Keep the spacer as thin as possible. I've always heard thick wheel spacers are more dangerous than thin ones. 1/4" should enough for you
Old Jul 22, 2011 | 11:36 AM
ok thank you - I found some on summitracing.com that are 1/4 and supposedly universal fit.
I may try them.
Old Jul 22, 2011 | 05:39 PM
I may try them.
You can get them that are made for your lug pattern
Old Jul 22, 2011 | 06:24 PM
I would stick with a 35x12.5 max on the stock wheel's and avoid the spacer's. Not worth it for an extra 1/2 inch of width. Just my 2 cent's
