Bad Front Wheel/Hub Bearing??
I just changed both front hubs and i till have a damn squeak in the passenger side wheel ![Frown](https://www.f150online.com/forums/images/smilies/frown.gif)
it sounds like its rubbing on something and it only squeaks at one point during one rotation of the tire.
what else could it be? rotors? brake pads? i have no idea.
i picked up both of my hub assemblys for 231.54
![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
To try to settle this I did an experiment. I have 35's and beat on the truck so the bearings wear out faster than a Grandpa truck. Stocks were replaced with Timkens, now with 95k the Timkens are done. I replaced the Passenger side with a Timken and the Drivers side with a Oreilly's china brand. They look identical except for the markings. We'll see which one dies first. Both only have a 1yr warranty. It seems like the quality control on most any aftermarket parts these days is horrible. Even brands that used to be good. Thanks China!
Hey Galaxy, I just did my front passenger hub today. A simple: mount 4 tires, change front pads and rotors turned into an all day fiasco. But it's done. The #4 is you need. It's a sealed hub. The job is easy just takes time. I would recommend torque wrench specs on the bolts that hold the bearing to the spindle. Also torque the cassel nut.
