Need pics of different tire brands and sizes
Old Jul 22, 2008 | 11:50 PM
bhill304's Avatar
I am gonna lift my 04 FX4 with a 2 1/2" levelling kit and an add a leaf for the rear. The local garages tell me that the biggest tire I can fit is a a 285/65 r 18. I believe I can fit bigger. I am looking for pics of any trucks out there with this levelling kit to get some ideas of what some different tires will look like.
Thanks.
Old Jul 23, 2008 | 12:47 AM
Nettershakes's Avatar
Usually the rule of thumb is 33's on a 2wd with a leveling kit, and 35's on a 4wd with a leveling kit. And 33's on 4wd with aftermarket wheels. There are other guys on here that can help you out. I got 33's on my leveled 2wd. I just need to get some better pics.
Old Jul 23, 2008 | 11:17 AM
wandell's Avatar
Right. With a leveling kit you can fit a 35x12.50 using the oem wheels. They will rub the control arms slightly at full steering lock however.
Old Jul 23, 2008 | 01:35 PM
Thanks.
I've got some pics of 33 and 35 inch tires in my gallery on my leveled 2004 4x4, 35 inch tires will fit if they are on the correct size wheel.
Old Jul 23, 2008 | 03:17 PM
cotedog03's Avatar
not really one to tell people to go search but...if you search the galleries you'll probably find a lot more pictures there than what people will respond with. theres a ton of guys running a leveling kit and 33's or 35's with pictures up
Cody
Old Jul 23, 2008 | 04:28 PM
stealth-Fx4's Avatar
Heres mine running 325/65-18 (35"x13") withs a 2.5 AS kit and 1" block. Rub off control arms at full lock...just turn back 1/4 turn and its fine
Old Jul 23, 2008 | 08:52 PM
These are 315x70x17 (35x12.5x17 BFG AT's) on 17x8 wheels. No rubbing.
Old Jul 24, 2008 | 09:57 AM
hill2107's Avatar
Paw paw did you have any rubbin or had to do any cuttin? I have some 20in Moto Metal 951 in the mail with some 35x12.50-20 toyo m/t's and wonderin if i may rub? I dont care to cut any plastic out from the fender wells and valence. What do ya think? I am getting the +18 offset 5.71 backspacing i think
Old Jul 24, 2008 | 09:43 PM
When the tires were on my 9" wheels I had to do a little trimming on the lower wheelwells. Nothing major. If you mount the tires on stock wheels or ones with close to stock specs you ought to be OK. The more you stick out in the front the more chances to rub.
Old Jul 25, 2008 | 12:02 PM
hill2107's Avatar
ok thanks for the quick reply
