Tire + Rim help!
Tire + Rim help!
I have bought and have at my house already;
20x8.5 6x135 Liquid Metal Wingman
with an Offset: 25
I want to get 305/55/20 tires on it, but now I cant cause the rim is only 8.5?
is there anything I can do to make it work or does anyone else have a 20x8.5 on 305/55's ? the tires are Nitto Terra Grappler
someone please help!
with an Offset: 25
The people I want to buy them off ebay said :
"According to the manufacturer these will be just too wide for a 8.5" wheel."
and I saw on some websites that sell the tire i want (Nitto Terra Grappler 305/55/20), they start at 9" and not 8.5, i just want to be sure it will work.
will 305/55/20 Nitto Terra Grappler tires work with my 20x8.5 rim??
does anyone know anyone else with this same setup? please let me know thanks!!!
305-55-20 shouldnt matter on 8.5 rim its only 1/4 in per side. on my factory 18x7.5 i have goodyear prograde 325-60-18 that tire recommends at least 8.5 minimum rim looks and works fine it just sqeezes the tire more. wears out a little faster. or uneven. so just a 1/2in overall wont matter at all
thanks guys,
my rims are Offset: 25
will this make a difference
also probably last question,
I have a 06 ford f150 xlt triton super cab 4x4, with no lift or leveling kit. will this work (20x8.5 rims & 305/55/r20) with no rubbing or problems? please let me know.
I would like to have as less space as i can in the area between the tire and car body.
thanks for all the help. thanks
can I just go with a 275/55-20 Nitto Terra Grappler? what will be different? will this make it look any different (height wise) and how? will it matter if I get this or the 305/55/20 ? if one would rub would they both? the rim is 20x8.5 with an offset of 25 which I think is a backspace of 5.75
thank you
also please give me your input! what tire would you recommend! please help me out!!!!!!!!!!!
like a 285/55? please help!
do they make a 285/60 r20?
thank you
Well im just going to go with the 305/55/20's since you guys say they will work, worse comes to worse I will have to get a leveling kit, which do you recommend just incase? thanks for all your help i'll be getting the tires within the week and post pictures in a couple weeks. thanks again
