what air pressure to be running?
Good rule of thumb:
P-rated tires not less than 90% of max.
C-rated tires not less than 80% of max
D-rated tires not less than 80% of max
E-rated tires not less than 75% of max
All of these suggestions are for 1/2 ton pick-ups WITHOUT a load other than the weight of the truck plus passengers.
Many people run the C, D, and E rated tires at a lot lower pressures than I've listed but once you start running lower than maxium pressures in LT tires (C, D, E tires) there load capacity diminshes exponentially, so you might as well not even have an LT tire. Especially people who are running "E" tires with 40 PSI of pressure.
Only if it is the same load rating as the OE. The recommended pressure for a LR C tire that comes on an F150 is 40. If he were to replace them with a P-series with a max of 35, he would be 5 psi over the max of the tire. In the reverse, if it came with a pseries that recommends 35, he would be 5lbs under pressure if he put on a LR C and even more with a higher load range.
tylerN, I looked at the Goodyear site and they only list 1 33" tire for a 20" wheel. That is an extra load P-series with a max of 44. I would not go over about 40 and under about 36 on those tires.
As far as 80% for a LR E with a max of 80, 60psi would be way overkill, even for a loaded 1/2 ton. And probably be bald in the center within 10k. I have run LR Es at 50 with excellent results, both wear and handling, with and without loads. I agree 40 is too low by far for those tires, but 60 is too high.
