2005 F150 Bfg At 285/65r18
I have a 2005 F150 with 275/65R18's. I need a new set of tires. I was looking at BFG AT 285/65R18's. Those tires are slightly larger than OEM. Has anyone tried it? Any difference in ride, turning radius, etc? I have a 100k mile extended warranty, do you think it would void my warranty? If I should go with the OEM size, what tire does everyone recommend?
Justin
Justin
I have a 2004 F-150 FX4. I just replaced my factory LT275/65R18 Goodyear Wrangler AT/S that had 63,000 miles on them. I replaced them with BFG LT285/65R18 two weeks ago today. I have put 900 miles on them so far and no problems. So far I would recommend them, they are a great tire with great wet pavement and snow traction. They ride a little stiffer around town because they are Load E tires.
Excellent Tire choice. Not sure if they would have an effect on your warranty or not, but you will be very happy with them. I was looking into them to. Discounttiredirect.com has a $50.00 mail in rebate right now FYI. They your speedo will read a little off since they are taller than your OE tires. Here's a link for that:
http://www.discounttiredirect.com/di...foTireMath.jsp
Originally Posted by PawPaw
That sound's like a E rated tire and 42 to 45psi ought to be fine. My tires are D rated at 50psi max and I run them at 42 to 45 psi, just check them for irregular wear and rotate as needed. I rotate mine every 10k miles.
