What Tire Size?
Old Jun 21, 2007 | 01:29 AM
reeder98's Avatar
Exclamation What Tire Size?
I'm gong to buy the 2.5" leveling kit and wanted to know what is the biggest tire size I could fit on there with the kit. I'm hoping bigger than 33's. And the biggest i would go is 315-75-16 "35-12.50" but don't know if it will fit. Also i don't want to re-gear or loose any of my power. So what do you recommend
4.6 Triton V8
Volant Cold air intake ~ est 13hp
Gibson exhaust ~ est 15hp
Superchip micro-tuner ~ est 50+hp
Old Jun 21, 2007 | 08:53 AM
keith_bennett's Avatar
If its a 4x4, you can fit 35s on your stock wheels or 33's on aftermarket wheels, but there may be trimming. If it is a 4x2, then 33's is the biggest you can go.
Old Jun 21, 2007 | 10:30 AM
wandell's Avatar
What year is your truck?
Old Jun 21, 2007 | 01:36 PM
I was guessing he had a 04+, but i guess i should have asked....
Old Jun 21, 2007 | 06:57 PM
reeder98's Avatar
its a 1998, sorry should have said that.
Old Jun 21, 2007 | 08:34 PM
wandell's Avatar
If it's a 4x4, you can fit 35's using the OEM wheels or 33's with aftermarket wheels. If it's a 4x2, stick with 32's or 33's. If you have a 4x4, you don't need a leveling kit because you can lift the front by adjusting the torsion bars to increase the preload (the same thing the "leveling kits" do except it's free).
Old Jun 22, 2007 | 12:01 AM
reeder98's Avatar
thanks, ya its a 4x4. how much should i crank the t-bars?
Old Jun 22, 2007 | 09:05 AM
wandell's Avatar
A lot of people crank the torsion bars up all the way with the OEM adjustment keys. Just keep an eye on your CV joint angles.
