I got rub
Old Apr 28, 2007 | 10:44 PM
kgascar's Avatar
I got rub
I tried to put on my new tires and they rub like crazy. 2006 xlt 2.5 AS level kit with 35 x 12.5 18 Nitto mud Grapps (stock rims). They rub on the upper control arm big time. I swore I saw this setup before and they didn't rub.
Old Apr 28, 2007 | 11:02 PM
wandell's Avatar
Most people have rubbing on the control arms at full steering lock with stock wheels and 35x12.50's. Tires with real aggressive side lugs like the Mud Grapplers have the worst rubbing. Is the rubbing just at full steering lock?
Old Apr 28, 2007 | 11:03 PM
smokestone's Avatar
Is your truck a 4x2? I have 315/70r17s on mine and nothing rubs. Maybe its the added height (.4") or added width (.2"). Switch them out for some BFGs
Old Apr 28, 2007 | 11:06 PM
djh1121's Avatar
IMO, that is a lot of meat for a 2.5" leveling kit...
Old Apr 29, 2007 | 11:53 AM
kgascar's Avatar
yeah there's rubbing when the wheels are straight. the side wall is about 1/4" away from the upper control arm and the lugs hit pretty hard (they are about 1/2" wide)
Its 4 x 4 and oh yeah I just dropped $1K on these so its not to easy to just switch them out for BFG
I guess I'll have to put in some spacers unless somebodys got a better idea
Old Apr 29, 2007 | 12:40 PM
BalogUK's Avatar
yea, my 35x12.5R18 procomps do the same thing- you learn to just deal with it, and not turn full crank!!!as the tires wear down, it happens less as the lugs aren't as deep. i've got 18.5K on mines with no adverse problems--other than the rub...
Old Apr 29, 2007 | 12:53 PM
kgascar's Avatar
yea that would be fine if it only rubbed at full crank but its rubbing all the time. I went a 1/4 mi. or so and it wore some of the lugs off and got pretty dam hot
Old Apr 29, 2007 | 05:13 PM
wandell's Avatar
How bad are they rubbing while the tires are straight ahead? You could run a small spacer.
Old Apr 29, 2007 | 05:17 PM
AZFX4's Avatar
Somethings not right there man. i just got 35 inch pjs on my truck and they have some mean side lugs and im not even close to rubbing with my tires straight. what wheels do you have?
Old Apr 29, 2007 | 05:29 PM
wandell's Avatar
He said he was using OEM wheels, like a lot of members have done with no problems. You did have the truck aligned after installing the leveling kit, didn't you?
Old Apr 29, 2007 | 05:36 PM
AZFX4's Avatar
yeah but he has an XLT just thought maybe there was a difference in the wheels than an FX4
Old Apr 29, 2007 | 06:22 PM
ruth's Avatar
i have the same problem with my 2006 fx4 s-crew. i had to use 1/4 inch spacers with my 35x12.5x18 toyo m/ts on stock rims. now i only rub at full lock
Old Apr 29, 2007 | 06:27 PM
BalogUK's Avatar
ahhh, i think you're on the right page AZ- if he's not 4x4 he would have some problems
Old Apr 29, 2007 | 06:31 PM
kgascar's Avatar
No I haven't had the alignment done yet. I was hoping to get them on and then take it in for an alignment. I was trying to do the geometry in my head and thought that would make it worse if anything but I could be wrong. let me know on that. That could be my problem
there's alot of rubbing its actually more like the side lugs are hitting the up. control arm, the side walls in between the lugs are only about 3/8" or so from the up. arm
thanks for the info guys I'm starting to miss her
Old Apr 29, 2007 | 07:15 PM
kgascar's Avatar
oh ya and I do have 4x4
