mushy brakes
mushy brakes
Originally Posted by rb4123
Did you remember to bleed the master cylinder before installing it?
If so, keep bleeding, and make sure your brake lines aren't bulging, and the seals on the pistons are good.
Just did my 99's pad and rototrs up front, adjusted up the back drums and totally flushed the fluid. If your useing the 2 man method make sure the guy in the cab pumps and holds and the guy crackin the bleeder opens slowly and closes before that pedal travels more than half thru the pedal throw. Do it till you have clear fluid and no trapped air. And yes do Pass rear, Dr rear, Pass front, Dr front last. I now have brakes that feel like a new vehicle.
the f250 light duty brake booster upgrade works absolute wonders also. i went from dangerously weak and mushy to super strong by replacing the booster and rear wheel cylinders and shoes. No kidding, the 250 booster is about 250% greater volume than the oem 150 one, the size different was ridiculous. I believe that the 250 one also has dual diaphrams
I know how to bleed brakes and i couldn't get my 97 4x4 to firm up for anything until the new booster...but i also have 200k on it
(btw, technically, there was nothing wrong with the orginal booster...no leaks, etc.)
i used the one man bleeder kit from autozone for like 10$. that worked for me. also make sure your rear shoes are adjusted correctly.that affects pedal travel as well. those self adjusters never seem to work right. the 250 booster bolts right up?? that does make sense its designed to stop a much heavier load.
