PROBLEM - Will 2" AS even help? - SEE PICS
Old 02-14-2007, 08:56 AM
Mange's Avatar
Eh, the fronts stick out just a bit more than the rears anyway, so I don't think it would be noticeable. Just make sure you keep your lugs torqued down on a regular basis if you plan on putting a spacer on.
Old 02-14-2007, 09:26 AM
sgerry's Avatar
Unless you are serious about mudding just trim the siping off the edge of the tire.
Old 02-14-2007, 10:24 AM
05supercrew's Avatar
Originally Posted by Mange
You also have about an inch less backspacing on your Helo's don't you? 5 3/8" ?
You are right.
Old 02-14-2007, 10:26 AM
Originally Posted by Riddoch
Is anyone out there running these wheel spacers or has anyone tried them?
http://cgi.ebay.com/ebaymotors/wheel...mZ170080173175
What is the general consensus on wheel spacers? Good? Bad? Solution to my problem?
Would I need all four or will a 1/4" difference in the front and back be unnoticeable?
If you couldn't tell I’m working on a budget here...
I ran those on a car and they worked fine.
Old 02-14-2007, 10:33 AM
Bryndon's Avatar
I don't typically recommend wheel spacer, unless some specifics are met:
1) the wheel has as much or more backspacing than stock - yours does.
2) only use a small spacer - 2" spacers just put too much pressure on the ball joints and wheel bearings.
A 1/4" difference front to back is unnoticable - I would use them only on the front and as I stated before, a 3/8" would be perfect, but a 1/4 should be fine.
Old 02-14-2007, 01:01 PM
wandell's Avatar
I agree.
Old 02-14-2007, 03:18 PM
onsracing's Avatar
the one's i used are similar to those, but i bought mine from rent-a-tire for $4.00 a pop.
Old 02-15-2007, 05:21 PM
Mange's Avatar
Hey, are you SURE it's rubbing there? Or are you just hearing your CV boot squeak? I just put my 325/60-18's (18x9 with 6 3/8" backspace) on my '04 FX4 and I have about a half inch between the knuckle and the tire. You may wanna put it back up on the jacks and look closely. In the pic, you have space. I rotated mine while they had it up on jacks and I could hear my CV boot squeak some while it was rotating (remember that front driveshaft will turn when you rotate the front wheels).
Old 02-15-2007, 07:43 PM
wandell's Avatar
Good point. It looks like there is room in the pic. My 22's are close, but they are not touching. Mine are so close that when a deer ran into our Expy it knocked the wheel into the upper ball joint/control arm.
Old 02-15-2007, 09:31 PM
Mange's Avatar
Ok, I'm running the same size tire as you, but with nearly a quarter inch MORE backspacing. No rub.
Old 02-16-2007, 02:47 PM
Riddoch's Avatar
I'm about 99% positive they were rubbing on ball joint at the end of the control arm. After I took the wheel/tire back off I could see exactly where it was rubbing. There was a nice shinny spot about the size of a nickel where it wiped the road grim off.
I'm going to try again on Sunday. Maybe I will try the passenger’s side this time.
Old 02-16-2007, 02:53 PM
pkent03F-150's Avatar
you dont have any room there you need to get a suspension lift and leveling. im surp that you cant fit them it mite be the backspacing
Old 02-16-2007, 06:03 PM
Mange's Avatar
Wipe some soapy water on the inner sidewall of your tire, then spin it all around and see if there is a stripe in the wetness from the rubbing.
Old 02-20-2007, 08:29 AM
Riddoch's Avatar
Man I am so pissed! The wheels and tires look great if only the didn't f'n rub so bad!
Photobucket is blocked here at work so bear with me.
You can see here how bad I am in need of some new tires.
I still do not have my Autospring on.
Quick Reply: PROBLEM - Will 2" AS even help? - SEE PICS
