Brake light help
Old Dec 10, 2006 | 03:58 PM
nascar_jimmy's Avatar
Brake light help
I have a 98 f-150. My turn signals work but my brake lights don't what could it be?
Old Dec 10, 2006 | 04:02 PM
Steve83's Avatar
Burnt bulbs.
GIGO !
Old Dec 10, 2006 | 06:32 PM
F151's Avatar
Does the third light work? Seems unlikely all three would go out at once. Unless there's a short.
Old Dec 10, 2006 | 10:39 PM
Colorado Osprey's Avatar
Fuse??
Old Dec 10, 2006 | 10:40 PM
Originally Posted by Colorado Osprey
Fuse??
always the best place to start, and i know ive overlooked the fuse before myself.
Old Dec 11, 2006 | 05:27 PM
GIJoeCam's Avatar
It won't be the bulbs. The brake and turn signals use the same filament. It could be fuse #13 (15A) in the fuse panel under the dash, but if that was the case, a lot more things wouldn't work, the shift-lock actuator being one of them. If the shift-lock works, it's not a fuse or brake switch issue. You'll want to check the LG wire for power when you press the brakes where it enters the multifunction switch on the column.
-Joe
Old Dec 16, 2006 | 10:41 PM
stumpjumper's Avatar
brake lights
-Joe
joe ;I came up with the same problem except third light does work does LG mean large green wire. I am not sure what the mal****ion switch is. any help ???
Old Dec 16, 2006 | 11:05 PM
GIJoeCam's Avatar
Yours is a different issue... Year, make, and model would be helpful.
-Joe
Old Dec 17, 2006 | 12:41 PM
Steve83's Avatar
Originally Posted by stumpjumper
joe ...does LG mean large green wire. I am not sure what the mal****ion switch is. any help ???
LIGHT green
MULTIfunction
Old Dec 17, 2006 | 08:12 PM
Red face brake lights
Originally Posted by Steve83
LIGHT green
MULTIfunction
steve; hay thanks I understand what switch your talking about. just took it awhile to sink in. that makes sence now.
thanks again, tim
Old Dec 18, 2006 | 06:44 PM
Thumbs up brake lights
want to thank joe and steve for the help. it was in the multifunction switch.
it was not bad . it turned out the hazard warning button was sticking. pressed
it on and off a few times and starting working.
