Caliper Clatter!
Old Apr 30, 2006 | 11:08 AM
Crownie's Avatar
Question Caliper Clatter!
I realize that the calipers are designed to float, but my rear calipers make a racket going down the road. I tighten the 2 caliper bolts, but there a lot of play left. Is there some way to tighten these up a little more to keep the rattle at bay?
Old May 1, 2006 | 09:23 PM
Colorado Osprey's Avatar
They float but don't touch anything, so what is the noise?
You can lube the sliders with a silicone caliper slider lube, but I suspect it is something else.
Old May 4, 2006 | 12:57 PM
Crownie's Avatar
The calipers themselves are loose... I tighten the bolts all the way and the calipers can still rattle within the bracket. I can move them quite a bit with my hand... and not just in / out. They move a good bit all around.
I've looked and can't find anything else that looks loose enough to rattle going down the road. I only notice this when driving slowly down the street. I have a couple small bumps (more like cracks) that it always happens on. If I have just the slightest pressure on the brakes I don't have the rattle. Now that I'm typing this I'm wondering what will happen if I have the parking break set a lil and go over these bumps. I'll try that tonight going home.
Old Jan 2, 2008 | 06:55 PM
paulplasma's Avatar
i have the same problem, what is/was the solution?
Old Jan 2, 2008 | 07:17 PM
NYfordguy's Avatar
New calipers and brackets? Or a few washers to tighten things up???
Old Jan 3, 2008 | 07:02 PM
paulplasma's Avatar
i am trying to avoid 'throwing parts at the situation' so unless new calipers is ONLY guaranteed solution, that is not an option. and the caliper is designed to float so "washers" is not an option either.
Old Jan 3, 2008 | 07:36 PM
NYfordguy's Avatar
Deal with it?
Old Jan 4, 2008 | 04:53 PM
NYh8tr's Avatar
Deal with it?
Since your comments are sooooo helpful and you are so eager to spend other peoples money when you dont know the cure,,, why don't you buy the calipers for paulplasma????
Old Jan 4, 2008 | 04:59 PM
NYfordguy's Avatar
I don't see your name with some suggestions. Just one post that is utterly useless.
Old Jan 4, 2008 | 09:13 PM
Bent6's Avatar
25 Year Member
First check the TSB's to be sure the factory has not addressed this issue.
I had a similar issue on a '91 Dodge Spirit R/T. It did get on my nerves. I wound up finding an anti-rattle spring off of a different Dodge and fitting it to my car. Basically it was a spring that mounted to the caliper mount and pushed the pads against the mount on the opposite side. The pads loaded between parallel slides, and the calipers floated in on pins/bushings. Is that how yours is set up?
