Pirelli Scorpion Zeros ?
Old 09-17-1999, 06:17 PM
BMW325's Avatar
Cool Pirelli Scorpion Zeros ?
Hey,
I have a 93 F-150, 2WD, 5.0, Flare Side. Right now it has FireStone FireHawk SS tires on it:
Front: 235-70-15 <
What the truck has now
Rear: 275-60-15 <
Stock Size Front & Rear: 235-75-15
I need to replace these tires they are about 70% worn and they look realyl goofy anyways (they where on the truck when i got it). I am thinking about replacing them with Pirelli Scorpion Zeros- 255-65-15 (front and rear). Do you guys think this size would look OK ? Also does anyone have any of these tires ? They look absolutley awesome and they have a speed rating of 150mph although I know the truck won't do it thats somthing to brag about hehehehe
Anyone have these or seen them ? What do you think of them ? Thanks !
Also if you would like to check them out here is a http://www.pirelli.com/tyres/cat/catric/scor0.htm
[This message has been edited by BMW325 (edited 09-17-1999).]
Old 09-18-1999, 09:09 PM
BMW325's Avatar
Question
Anyone ?
Old 09-18-1999, 10:07 PM
54regcab's Avatar
Cool
I think those tires would be a litte short.
I have no idea how wide the rims on a '93 are but check to make sure the tires aren't too wide to fit the rim properly.
A 255/70/15 I think would be a better choice.
This tire would be closer to the original diameter that came with your truck.
I personally would never put a smaller than stock diameter tire on unless you are going to lower the truck.
99 XLT 5.4L reg cab
4x2 120" Wheelbase
4 wheel disc brakes/ABS
5 star larait style wheels
Toreador Red/Silver
3.55 gears 255/70/16 OWL
Delta toolbox
Eclipse 5340 cd player
Memphis ARCS50 component speakers w/tweeters mounted flush in the door panels (excellent sound)
Sherwood 35x2 RMS amp for components.
Jensen 50x2 RMS for subs.
2 6.5" Bazooka tubes
Lowering shackles?
Columbia SC
Old 09-18-1999, 10:46 PM
BMW325's Avatar
Post
yea the truck has 15x7 wheels on it. The Scorpion Zeros are not avaliable in:255/70/15
I figured up the difference between the stock tires and the 255/65-15s here is what I came up with:
235/75-15:
Sidewall 6.93"
Diameter 28.87"
255/65-15:
Sidewall 6.52"
Diameter 28.05
So it looks like the total height of the 255/65 will be will be about 0.8" shorter than stock. Which would make my speedometer show about 2.86% too fast. I don't think that .8" would make it looks that bad at stock ride height. But I may be wrong
Old 09-19-1999, 12:10 AM
54regcab's Avatar
Post
Why do you want the Pirellis so bad?
They are an excellent tire but are better suited for performance cars.
I would love to have a set on a Mustang but I think a truck needs a truck tire.
I personally think the stock tires on most trucks don't fill the wheel well enough.
There are tons of threads about tires and how they look/perform.
What rim do they recommend for that tire?
I think if you went with these tires you would end up with a lowrider look.
If that is what you are going for then the pirelli is probably a good choice.
I wuldn't run less that a 70 on your truck unless you get wider rims.
Old 09-19-1999, 09:45 AM
BMW325's Avatar
Post
The reason I want the Pirelli so bad is ebcause I think the tires would look awsesome on my truck but I don't want to go spend big bucks for some 17" wheels. By the way my truck has the ground effects on it:
http://www.angelfire.com/ky2/ford/images/truck2.jpg
That is a pic of it the way it is right now. By my calculations the new front tires would be .8" shorter and the rear would be .2" taller.
[This message has been edited by BMW325 (edited 09-19-1999).]
Old 09-19-1999, 04:19 PM
LowDownFord's Avatar
Post
54regcab, I beleive the Pirelli Scorpions are a light truck/SUV rated tire. They offer an excellent grip on the road wet or dry.
Old 09-19-1999, 06:06 PM
54regcab's Avatar
Thumbs up
Now that I know you have the ground effects and have seen a picture of your truck I recommend getting the pirellis.
Quick Reply: Pirelli Scorpion Zeros ?
