33" tires on a 2wd?
33" tires on a 2wd?
I have a 2wd STX with 17" rims and want to put the 33x12R17 pro comps on it. I have a 3" coil and A arm lift. Can I put the tires on? If rubbing on the suspension components is a problem can I use a wheel spacer?
1998 F150 STX 4.6L
2" Lift coils,
265/75R17Goodyear RTS
K+N filter charger
White Face Gauges
Leather "Harley" seats
1998 F150 STX 4.6L
2" Lift coils,
K+N filter charger
White Face Gauges
I have a 2wd, sport package, same as stx, with no lift and 285/75r15, which are 33x11.4 and they fit fine. You won't need the lift, but it shouldn't hurt. You will want to avoid wheel spacers b/c they make your rims no longer hub centric and therfor weaker. What you will need is rims with the correct offset. I think that if you get some with 3.625" back spacing that should be fine. But don't go more than 4" or you tires will rub when you turn. If you already have the lift on there, that's fine. I'm not sure it will work perfect with the lift because of the increased wheel travel. I do know that it will work with no lift because there is little wheel travel so they pretty much stay in place. I think that for my 2000, there is about 3-4" of travel up front. That's nothing. I know this sounds backward with the lift possibly hindering the correct fitment, but that's what happens with lifts. As for the back, there won't be any problems. Hope this helps.
2000 Silver F-150 XL Sport
Reg. Cab, Reg. Bed, 4.2L V6, 5-speed, 4x2
mods:
Tailgate lock, Generic bedliner
285/75r16 BFG AT ko (32.9x11.4)
Sony CD player, Blaunpunkt 5.25" speakers
Crimeguard alarm, Power locks
Never let your schooling interfere with your education --Mark Twain
mods:
First of all, a 285/75 tire is NOT a 33" tire, it is a 31". A 305/70 is a 33". You want to mount the new 305/70/17 PRO-COMP tire on your stock Ford 17" inch rim. They will fit, and you will need that lift you have. The only problem you will run into is due to your 7.5 inch rim. The tire will balloon slightly with such a narrow rim and might rub your control arm. You can cut the bottom plastic spoiler if necessary as well as the plastic inner fender. You should be ok with that set up. Is the back lifted at all? Even a 1.5 inch block would work. Good luck, PRO COMP tires are great.
r0Land...are you sure you have a 15 inch rim?? And of you do, why?
1999 Blk F150 Sport 2WD 5.4 Drk Graphite Captain's Chairs, fully Loaded.
Flowmaster cat back 3 inch 70 series muffler w/ 5 inch case, K&N GEN II intake, Superchip, 4:10 Gears.
6.5 inch CAMBURG lift w/35/12.5/16.5 BF muds on Weld wheels.
Dual Billet grills, full tint.
AUDIO= Alpine LCD monitor Head unit, Alpine DDrive Separates all around, 2 JL10 W0 subs in fully custom fiberglass enclosure under reaer seat. Powered by Fosgate POWER series amps. SO CAL RIDE...
<font face="Verdana, Arial" size="2">Originally posted by GRIDE:
</font>
</font>
A 265/75/16 is 31.6"
A 305/70/16 is 32.8"
The only differance between the 285 and 305 is width. the 285/75 is depending on maker 11.2-11.6 where as the 305/75 is 12" wide
'99 F-150
4.2 4X2 XLT
- 3" spindles
- 285/75/16 Cooper Discoverer STT
- Pacer 16X8 Aluminum Wheels
- cat back duals with Flowmaster 40 series 36"x3 1/2" chrome tips
UB6IB9,
you have a nice lookin truck.
98 Black F150 S/C 4x4 ORP 5.4
4" Rancho lift, 14 KC lights, lots of other goodies. Check out www.F150World.com/Mudder for pics and all the info.
Thanks for the clarification, UB6IB9, your exactly right. btw, nice looking ride!
GRIDE, I have a 285/75r16 tires, that would imply I have 16" rims. Secondly, a 305/70r17 is a 34" tall tire. Try getting your calculations right before you go telling others they are wrong.
mods:
[This message has been edited by r0land (edited 03-30-2001).]
mods:
r0land....
In you original post, you state that you have 285/75r15 tires. In your signature, you say that you have 16" tires. You are confused buddy. This why I asked you if you were sure that you had 15" tires. DOn't be so frisky in the future until you check up on yourself.
As for my calculation, it was improper due to that fact that I used a 15 inch tire instead of a 16, that was my mistake. The PRO COMP 305/70/17 is the equivalent of a 33/12.5/17...close enough anyway.
Why don't you guys just suck it up and lift your trucks before you go putting 33's on them...they look like crap at stock height. It looks as bad as putting very low profile tires on a car without dropping it. That is just my opinion though.
As for you r0land, chill out, I asked you a simple question about your confusion.
hey gride, i was in oceanside, ca 2 weeks ago for spring break and saw a truck that looks just like yours sounds, just curious if that might have been you? and you'll have to forgive roland, them boys in austin aint like the rest of us (just a joke). take it easy.
***JasoN***
Oxford White 1998 F-150 STX, reg. cab, flareside, 4.2, auto, 3.55s, tint, Prestige alarm, Bel radar detector, Pioneer CD player, 4 Polk 5x7's, Stull billet grille and bumper insert, Flowmaster exhaust, K&N airfilter, V-Tech Tailight Covers(painted to match truck), removed factory mud flaps, Clear Corner Lenses, DJM shackles(removed for lift), Billet Oval Mirror, 3in. Body Lift, lift lips, chrome tow hooks, Pilot driving lights mounted behind billet bumper insert, 16x8 Ultra Wheels, 305/70/16 Goodyear AT/S, Custom door ding from some a$$hole, Fabtech Spindle Lift, 2in. blocks out back FUTURE MODS: rancho rsx shocks, 1 1/2in. coil spacers, 2in. add-a-leafs, 315/75-16 yokohama geolander mt's, and still working on getting that dang door ding fixed . . . FIGHTIN TEXAS AGGIE C/O '03
***JasoN***
Hey, Gride, you are right, in my orig. post, I had the 285/75/r15, that was my bad. But the only reason I was so "frisky" was that you were equally "frisky" in your post. If your gonna dish it out, you better be prepared to take it as well.
dwdodd, where did you get this #, .03937, from? Last time I checked, there are 25 mm to an inch.
BFG, lists their all-terrains as 32.9" in diameter. What does this mean? Tire manufacturers vary the actuall diameter of their tires a bit. In the end, the true diameter is partly due to the ammount of air pressure in your tires and the weight you place on them.
Nevermind, just figuered out where that # came from, it is a more accurate # for the conversion. There are acctually, 25.4 mm /inch. So your #s are more accurate, but the above statement about how different tire manufacturers vary the actuall tire size they use still stands true. Thanks for the correction.
[This message has been edited by r0land (edited 04-02-2001).]
