will 305's fit on stock 16x7 rims?
yes, they will fit. You can fit up to a 315/75R16 (35x12.5x16) on a stock 16x7. It bulges a lot, but hey, it looks good. A friend has 305/70R16 Baja Claws on stock 16x7 rims...its a chevy, but they measure the same. I know you can fit em though, 'specially with a lift if you have one. If not, you might have to trim some. Hope this helps...
-Brandon Warford
97 F150 4x4 Sport Brt. Red SuperCab
4.6l Triton V8
3.55LS
3" Performance Acc. Body Lift & lift lips
1-1.5" torsion bar adjust. so it sits level
Clear Corner Lenses
315/75R16 Yoko. Geolander MTs
American Racing Atlas 16x10
Pioneer 8000 3D series
Boston Acoustic 5x7s
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
True Dual Exhaust
--(2) Stage 3 Flows (Exits like the Lightning)
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
Repaint around Headlights where clearcoat is coming off >=(
Possibly a Manik Brush Guard and Roll Bar--we'll see
Thats about it for now!
Killintime4fun@aol.com
"THROUGH the river and OVER the woods to grandmother's house we go."
"...the road curves to the right and there are a lot of signs that say you cannot turn left...TURN LEFT."
-Brandon Warford
4.6l Triton V8
3.55LS
Clear Corner Lenses
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
True Dual Exhaust
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
NO NO NO NO they are not made for that size of a rim they need at least a 8" rim I have seen them on a 7" but you can run the risk of haveing a blow out. if you don't want to go and buy new rims I would put on the BFG 295/75r16 they should work, or go out and buy a 16x9 that would be the best..
Bigred where do you get your info? we all need to be carefull and look out for our fellow members and not stear them down a road that they can get hurt.. you see a lot of people doing things and sometimes there are not the safest thing to do..
I got my info from work at I work for goodyear...
Latter all
New Toy To Play With
2001 Ford Ranger Edge
Black Extended Cab 4x4 Off Road, With Dark Gray Interior, 4.0L, 4.10 Gears,
Things it Came With
Pionneer 6 Disc In-dash CD player
Nurf Bars (painted to match)
Painted Bumpers
Fog Lights
Add On's for now
none yet (he he)
Superchip Soon
Old Truck
1999 F150 Bright Red
Extended Cab 4x4 Off Road, With Gray Interior, 5.4L, 3.73 Gears,
Add On's for now
Access Tunnel Cover, Stainless Steel Nerf Bars, Stainless Steel Rocker Pannels, Putco Bed Rails, Clear Turn Signals, Flowmaster Exhaust, Painted Vent Shades, Painted Taillight Covers, Painted X-Cab Covers,Superchip, Airaid FIPK, Red Stering Wheel Cover, Pionneer CD Deck
Link to Pictures..zing.com
Latter all
Things it Came With
Painted Bumpers
Fog Lights
Add On's for now
none yet (he he)
Superchip Soon
Old Truck
Add On's for now
kipg-we shoould think about safety it is like ski-diving thousands of people jump out of a plane and there ok but there is the chanse that you might not be ok and hit the ground a little faster that you want to.
Hotrod-I looked and the bolt patterns the same for the F150 and Navigator, but I don't know about the backspacing I will try to find out and tell you tomorrow.
i hope you listen to the ones that have done this the right way...
latter all
latter all
I guess you can look at this two different ways. Yes, they will fit on stock rims, on the other hand, is it smart to put them on stock rims? Tech data says no.
I think 'millions of others' is stretching it a bit, but there are several others that run 305s on 16x7 rims w/o a problem.
I took the advice of people that do this for a living and bought 16x8 rims for my 305s even though I didn't want to.
If you like the look and want to save the money, go for it. Personally, I think the 16x8 are too narrow for 305s and doesn't 'look good', but that's only me.
'98 F150 S/C 5.4 V8 4x2, Aggie maroon, spindle lift, blocks and leafs, Rancho RSX shocks, Airaid filter system, Pro Comp 305/70/16, AR Baja 16x8, Dynomax duals, and some other stuff
MN99F150-1: Not to be rude AT ALL, , but I have never heard of having a blowout because you stretched rim size 1" farther than recommended. I know a friend who has 33x12.5 on 15x14 rims. They look like crap, but if he keeps the air pressure high, its not a problem, lowering to 14 psi or less will cause him to blow a bead or allow the tire to come off the rim (he's done it a couple times offroading). Several of my friends are running 315/75s or 305/70s (same width) on a 16x7. Just keep air pressure normal. A friend of mine who owns a tire shop and does a lot of offroading says "you can actually fit the tire on a 16x6 rim, but that's risking it- 16x7 IS ok". Like i said, i've never heard of this happening. But thats me. I almost ran this setup. But got new rims instead. Anywayz, hope this helps someone!
-Brandon "BigBad"
[This message has been edited by BigBadRedLiftedFordMan (edited 01-27-2001).]
-Brandon "BigBad"
Wheels fit
Yes they fit I just got a good used set from navigator wheels on my f150 2003 and they look great
