Synthetic Doubts?
But it still ain't a Harley!!!
Beastrider.
I guess I should have been more specific. Yes, it's a Japanese 4 banger, a 1984 Nighthawk to be specific (CB700SC); and it has 40k miles on it. It's already sprouted a couple of small seal leaks, although it took about 13 years to do it so I can't complain.
I've been considering changing to a synth because the oil goes in 20w-50 and comes out looking like dirty water, and that's after only 2000 miles. I've tried synthetic blends and no difference.
You say it won't affect the wet clutches but how will affect the seals? What kind of experience have you had with these kinds of issues?
Originally posted by Indyfan
Beastrider.
Beastrider.
I would say you should have no problem. Though I would use a motorycle specific oil that is compatible with wet clutches.
Synthetic Oil
I have to agree with mdparks. Millions of miles have been put on Gold Wings with synthetics, with Mobil 1 being the most often used. I just don't think you can go wrong with a syn for your bike.
The synthetic should stand up better to the long chain breakdown caused by the transmission gears. And for multi weights, synthetics need less of an additive package to achieve a wide winter/summer rating.
For your bike, I'd opt for a 20W/50, or maybe a 10W40.
Experience: I've owned a Honda 600 VLX, an old Kawa 650, a Triumph, and most recently a Valk. the VLX (6000 miles) and the Valk (26,000 miles) most had syn in them, in the case of the Valk Exxon 5W 50.
I've stayed on top of the oil issue for a long time. In the early days of synthetics, seals could be a problem because of the base stocks used, but that is no longer the case. YMMV.
Originally posted by LaunchinLiteLariat
OKThink about it this way, there are way too many people saying way too many good things about sythetics to not have some sort of truth to it. Unless your're just a skeptic... and if so it's your loss!http://www.royalpurple.com/testimoni...rple Motor Oil
IMHO the only thing lost is an extra $10 or $15 of your money!!
Heya STX/98 you can consider that good money spent on a warm fuzzy feeling it gives me, kinda like that radar detector gives to you LOL!!
Hey, I'm sold. Seriously. I'm going to switch my 99 F150 and my wifes 01 Sport Trac, AND, my 1970 Cutlass over to synthetic. No joke. But I was going to put a Bell remote radar detector in the F150. Are you suggesting the Bell would not work suitably for police radar? No jokes. For oil, I'm going to get three cases of Mobil one and three K&N oil filters. But, what about the Bell remote detector? I know it's off the thread, don't want to tread, but I need to know what's said. Oh gosh, is that a rap tune in the making??? (i'm 41, give me break here)
I put Valvoline synthetic transmission fluid in my 1999 F-150 4.6. I used Valvoline because it was the only sythetic fluid I could find that met the Mercon V specification.
I read that the synthetic fluid can reduce your transmissions operating temperature by up to 50 degrees. Since I tow a 4000# travel trailer I felt that I needed the extra protection.
Your thoughts?
Your thoughts?
Re: What about synthetic trans fluid?
Your thoughts?
Your thoughts?
Story. Buddy of mine full time RVer. Taking his RV over Donner Pass in CA. Max temp his transmission saw was 180 degree. He said before he switched 220 was the norm for mountain passes, even higher during the summer.
Heat kills the transmission and the fluid. If you keep it cool it will last.
