Speed density?
Old Jan 22, 2000 | 09:25 PM
qtrmiler's Avatar
Post Speed density?
How many mods can you get away with using the speed density on a '94 with a 5.0? Thinking about a crate motor TFS heads & a X303
Old Jan 22, 2000 | 10:52 PM
StrangeRanger's Avatar
Post
You're probably pushing the envelope too far with speed density. See my post on this at https://www.f150online.com/f150board...ML/000096.html
Old Jan 29, 2000 | 04:38 PM
Flip's Avatar
Post
I have heard that an increase of 10% will not affect the speed density PCM. The mods that you listed will probably go beyond that.
Old Jan 29, 2000 | 05:30 PM
fast46triton's Avatar
Post
Flip...From Www.pickuptruck.com?
Old Jan 29, 2000 | 08:14 PM
mtucker's Avatar
Thumbs up
Check this out.
http://www.fordvschevy.com/ubb/Forum18/HTML/000268.html
1999 XLT SC, bright red, 4.2l, 5 speed, MAAP stainless nerfs, Prime Designs bug deflector, Astro Euro-Lid II, Mobil 1.
Old Jan 29, 2000 | 09:52 PM
Pastmaster's Avatar
Post
I always wanted to run a larger lobe cam in my F-150, but was told by several mechanics that SD won't allow it. And a 600 switch to MA isn't worth it. I can get a new intake and carb and switch from EFi cheaper.
Old Jan 29, 2000 | 10:48 PM
Don C's Avatar
Thumbs up
Put a Ford MotorSports Mass Air conversion kit it.
Part # M-9000-T50 manual trans
M-9000-T51 Auto Trans
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bassani Cat Back, Superchip,Modified intake with modified K&N filter.
Old Jan 31, 2000 | 12:33 AM
Flip's Avatar
Post
Flip from www.ford-trucks.com. I don't remember going to Pickuptruck.com but maybe I did. I just went tho the site and nope it's not me.
[This message has been edited by Flip (edited 01-30-2000).]
Old Feb 9, 2000 | 08:25 AM
Lightnin Struck's Avatar
Post
Yup, that X303 will kill you if you remain with Speed Density. Anything that radically changes vacuum(X-303 for example) at idle or at cruise will result in bad drivablity and possible lean conditions. Minor cam changes are no problem, talk to a reputable cam grinder(Crane,Comp Cams) and they can grind you a SD friendly cam. Usually heads are not a problem and superchargers aren't a problem, pretty much just cams.
Curt
93 Lightning #4232
