best way to get at oil filter on 1999 f-150
Old Jan 30, 2000 | 03:24 PM
rangerr91's Avatar
Post best way to get at oil filter on 1999 f-150
what is the easiest way to get at the oil filter on a 1999 f-150? it looks buried in there. thank you
Old Jan 30, 2000 | 03:48 PM
PaulT's Avatar
Exclamation
Rangerr91,
I have to crank the wheel all the way to the right so the filter will clear the steering linkage! It's a pain in the butt getting the filter off and always makes a mess! There have been several posts about poking a hole in the filter to drain it first and using folded cardboard to channel the oil away from the crossmember under the engine! I've not tried either, but may at my next oil change! Good luck!
Paul...
99 F-150 XLT SC Sport, 4.6L, Auto, Captain Chairs, Class III Towing Package, 3.55 LS, Sliding Rear Window, White, 4X2, CD, Soft Factory Tonneau Cover, K&N Filter, WMS Velocity Tube, Line-X Spray on Bed Liner, Gibson Side Swept Cat Back System, F150online Decal...
More to come!
ptarnuzzer@megsinet.net
Old Jan 30, 2000 | 05:17 PM
Dunbarton's Avatar
Post
Ranger, Paul,
You guys have 4x4s?
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The occasional Z-71 Eater! Wedgewood & Denim, SuperChipped, Airaid FIPK, Rhino Liner, Extang Classic tonneau cover, Mobil 1. Man, I got it all! (New Jersey)
Old Jan 30, 2000 | 06:54 PM
Yankee's Avatar
Post
Hey it's painless if you break it loose with a strap wrench and then put a plastic bag around it and then unscrew it. NO MESS! p.s. I have a 4x4 and it does take two hands to guide it out.
Old Jan 30, 2000 | 08:06 PM
Dustoff's Avatar
Post
I have a 4x2 and I also have to crank the wheel to the right. It still requires a little work to guide the old filter out..but not that big of a deal.
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
Old Jan 30, 2000 | 10:27 PM
Spyder207's Avatar
Wink
I've tried twice and still think the best position for me is on my fat *** in the waiting room of my local Ford dealership.
1999 F-150 XLT Supercab
Black factory steps
Flareside Sport Package
Oxford White
Full tint
Bug Shield
CD player
17" wheels, K&N
Ford Soft Tonneau Cover
Gibson Super Truck
"Did it myself" Undercoating
"Freak on a Leash"
Old Jan 30, 2000 | 11:56 PM
PaulT's Avatar
Exclamation
Dunbarton,
I have essentially the same truck as you!
Paul...
More to come!
Old Jan 31, 2000 | 01:39 AM
Neal's Avatar
Cool
HI!... I never have a problem changing my oil filter. I just turn the wheels to the right and use a filter wrench to break the filter loose. My truck came from the factory with a sheet metal drain sheild directly under the filter on top of the cross member. I drain my oil first and then put the oil pan under the sheild and it all runs into the pan when I loosen my filter. After you install the new filter just take a shop rag and wipe the sheild and your done. Clean and simple!LOL!
NEAL [ the horsepower freak ] NEWMAN
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, **** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, AUTOMETER guage pod and tranny temp guage, custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP.
FUTURE MODS : JBA headers, power pulleys, twin electric fans, traction bars, BAUMANN ENGINEERING shift kit, POWERAID, and a KENNE BELL BLOWZILLA supercharger.
ESTIMATED H.P TO DATE : 310H.P / 405ft/lbs of torque.
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w 530H.P(natural), 750H.P with N.O.S, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Jan 31, 2000 | 03:08 PM
MN99F150-1's Avatar
Post
I don't have this problem mine is under my front bumper, sucks if I hit someone and nock it loose but if it is not my falt than let it run till it goes then a new motor, lol. Try to see if you can get the remote filter kit from ford. Lots of luck to all.
1999 F150 BRIGHT RED EXTENDED CAB 4x4 OFF ROAD, WITH GRAY INTERIOR, 5.4L, 3.73 GEARS, ADD ON'S BELOW
ACCESS TUNNEL COVER
STAINLESS STEEL NERF BARS
STAINLESS STEEL ROCKER PANNELS
FLOWMASTER EXHAUST
LUND BUG GUARD
GTS HEAD LIGHT COVERS
K&N AIR FILTER W/ AIR BOX MOD
PUTCO BED RAILS
RED STERING WHEEL COVER
PIONNEER CD DECK
WISH LIST: F1 RAM AIR HOOD, TINTED SIDE WINDOWS, BRUSHGUARD, WIPER CRAWL, VISOR, LIFT W/ 34" TIRES, ECT,ECT...
Old Jan 31, 2000 | 06:28 PM
Dunbarton's Avatar
Post
PaulT,
I can't believe Ford changes the oil filter location so often. Mine is right next to the drain plug hanging vertically. It's Right there, no obstructions, just turn it off and on!
