F150 issue needs help
Old 03-22-2022, 09:21 AM
1hurley17's Avatar
I’ve got a 2006 f150 5.4 3 valve and one day as I’m going down the highway it tried to down shift and when it did it lost all power and was in like a limo mode it idled horribly touchy like it was missing really bad well I eventually got it home tore it apart and it was a broken guide so I did a full timing job besides the phasers and it runs the exact same but I don’t have any codes besides o2 sensors which are gone cause of my exhaust I assume it’s the passenger side phaser but there’s no noise and it only runs rough after the engine temp gets to the middle or close to it but while it’s cold it acts like nothing is wrong I’m 1000$ in the hole at the moment so I’d like to replace that phaser amd see what it does but I need some concrete proof that’s what it is
Old 03-22-2022, 10:19 AM
glc is online now
A "full timing job" should include phasers, chains, guides, tensioners, VCT solenoids, and a Melling high volume oil pump.
Old 03-22-2022, 10:46 AM
1hurley17's Avatar
Yeah there’s not much I don’t know except can the phaser be bad with no noise and just rough idling and performance
Old 03-22-2022, 11:16 AM
Roadie's Avatar
The purpose of the phaser is to advance and retard the cam timing based on engine rpm and load. If it isn't working properly, I don't know of any reason why the engine should make noise unless it can cause preignition. But, I ain't no mechanic, just a shadetree.
Old 03-22-2022, 12:20 PM
1hurley17's Avatar
Roadie
Everything I’ve read so far says that the most common thing to look for when they go bad is that they make a medal clanking noise I just wanna be sure that’s what it is I’ve changed everything but the phasers and oil pump
Old 03-22-2022, 02:01 PM
glc is online now
Change them both. Low oil pressure will cause this issue. Except for the oil pump you should use Motorcraft parts. It's possible debris from the guides is in the oil pickup screen, clean out the pan if you can.
Old 03-22-2022, 02:04 PM
1hurley17's Avatar
I’ve already cleaned the pickup and pan along with new oil and filter all motorcraft homestly I’m worried my calves are ****ed up
Old 03-22-2022, 04:31 PM
glc is online now
Calves?
Old 03-22-2022, 04:34 PM
1hurley17's Avatar
Sorry
I meant valves
Old 03-22-2022, 09:45 PM
Roadie's Avatar
I think that when the valve train noise starts, that usually means the oil pressure is low at idle speed.
Old 03-22-2022, 09:56 PM
1hurley17's Avatar
Yeah so no noise at this point just runs like **** when it gets warm and bucks when I hit the accelerator
Old 03-22-2022, 11:19 PM
glc is online now
Any OBD2 codes?
Old 03-23-2022, 02:39 PM
BillSF9c's Avatar
I'm weak on 3Vs, but adding this up, phasers affected by oil pressure. "Known" weak oil pump. Works when cold - (THICK OIL = HIGHER PRESSURE.) MY conclusion says, chg the oil pump. Melling is always suggested .While there, phasors have not yet been changed. Aside from guides, I dunno if phasors can be damaged, like guides, but since suggested by Senior guys, it IS a thought!
Earlier years of 3V seemed to have this problem, more.
Good luck.
Quick Reply: F150 issue needs help
