2006 f150 won’t start
Old 01-31-2019, 04:32 PM
Charles Brading's Avatar
Will turn over and act like it will start then doesn’t. One day it just quit while driving up a hill. Lost power and died. I’ve changed fuel pump because there was a leak problem in the bed and it was rusted out. So I know it’s getting fuel. But I’ve been told it my cam phasers. Also been told it could be a computer problem. And I don’t know enough myself to tell. I’ve checked codes but battery goes dead very fast and then when I charge it up I don’t get any codes. It’s a brand new battery also. Any help or advice would be greatly appreciated. Thanks
Old 01-31-2019, 05:50 PM
glc is online now
Check the FPDM for corrosion. It's on the frame above the spare tire, the backside rots out.
Old 02-22-2019, 10:46 AM
Replaced fpdm
Gettin fuel now cranks but doesn’t fire up
Old 02-22-2019, 11:43 AM
glc is online now
You need to actually test for spark and fuel injectors firing. See if any local parts stores have a set of noid lights and a spark tester for rent or loan. Have you checked all applicable fuses and relays?
If your battery goes dead fast, it sounds like you have a short somewhere.
Might be time to get a pro involved.
Old 02-22-2019, 12:27 PM
projectSHO89's Avatar
How do you KNOW it is getting fuel?
Old 02-22-2019, 03:32 PM
Yeah I have checked for spark but have not checked the injectors. And I team threw all the relays and fuses. I’m starting to think the same thing myself. My costly
Old 02-22-2019, 04:14 PM
glc is online now
Does it or does it not have spark?
Old 02-22-2019, 07:17 PM
It does have spark
QUOTE=glc;5247529]Does it or does it not have spark?[/QUOTE]
Old 02-22-2019, 09:43 PM
glc is online now
How did you test for spark?
Quick Reply: 2006 f150 won’t start
