scooley
Old Jun 1, 2013 | 07:05 PM
scooley's Avatar
Exclamation scooley
hi all I have a 2006 f150 -fx4 with a 5.4l. My problem started 3 days ago, the wrench light and engine light came on. After making it to auto-zone to get code read it came out to be a p2106. I purchased a new throttle body from ford and installed. I was also getting a p061B code from my programmer. (sct) After numerous trips to ford mechanic and others in my area, and replacing the MAF(mass Air Flow sensor) the engine is still tripping the wrench light. The outcome thus far is the problem isn't repaired, and the ford mechanic doesn't know what is causing the P062B code to continue to appear. Can anyone help me with this problem. please email me at sallyandshane2008@yahoo.com if you can help e with my problems or need ore details. your friend scooley
Old Jun 1, 2013 | 07:06 PM
scooley's Avatar
sorry the code is P061B not P062B
Old Jun 1, 2013 | 09:32 PM
JackandJanet's Avatar
Scooley, I moved your thread into the V8 engine section. You might get a better response here. Welcome to our forum!
I did a quick search on the P061B code, and it seems to be a problem in the PCM related to torque calculation. Have you installed a programmer that changes the tune in the PCM? This seems to be a common cause.
If not, perhaps the dealership might flash your PCM to the latest calibration if that has not already been done.
Others may have much better advice. Keep checking back.
- Jack
Old Jun 2, 2013 | 08:01 PM
scooley's Avatar
yes I had a sct programmer on it but reset it to stock and after ford ran 2 reprogramers on it the problem still exists. my problem is it doesn't do it all the time it isn't that there is something I can do to make it happen when I need it to so totally weird.it also still does it with the programmer on stock setting. pulling my hair-out
Old Jun 2, 2013 | 08:03 PM
scooley's Avatar
new throttle body and mass air flow sensor and am in the process of going through all fuses to check. als prior thanks to all for any help. its like having a lame horse
Old Jun 5, 2013 | 01:53 PM
scooley's Avatar
hi all the latest on the p061b code for my 2006 f150-fx4 5.4l. I took the truck to a different ford dealer to a well known mech. he found the wiring harness had spot that the wires were exposed, so I am replacing the harness. in my finding there are numerous parts this code affects from the crankshaft sensor, camphasers, abs, maf, throttlebody are some that I found this code reflects back to.
Old Jun 5, 2013 | 09:19 PM
scooley's Avatar
lack of power
can anyone help me find why there is such a tremendous loss of acceleration when programmer is on stock,in a 2006 5.4l f150
