radiator problems with my F-150?
Truck specs
1998 F150 4x4
4.6 L V8
Automatic transmission
179,000 plus
Need some help/answers from some vets with my radiator problems with my F-150?
I had transmission fluid overflowing in my Degas bottle so I called around and got some quotes on how much it was to replace a radiator. Too my shock one placed quoted me $810 down to $510. I’m not rich so I wanted to do it myself.
Removed cooler line on old radiator, removed Degas bottle and 3 other hose that attach to the system a total of 5, 3 rubber and 2 steel lines (cooler transmission lines). Cleaned out degas bottle before new replacement of new system installed.
Flushed transmission fluid as it was almost pepto bismol looking in color and replaced the transmission filter. Put Merc V back in system and filled to the correct level.
Installed new radiator replaced all lines flushed system at least 7 times at 15 min intervals. The problem I’m having now is degas bottle is still getting some transmission looking pink fluid in it. Not a lot but I’ve did a system flush and the transmission fluid is pepto looking color again.
So my question is could I have gotten a bad radiator or could I have screwed this up? I hoping you can provide me with some answers. Thank you
Crypto.
1998 F150 4x4
4.6 L V8
179,000 plus
Crypto.
Has your Transmission fluid level changed? I might think if it can get into the radiator it could go the other way and get into the transmission. I've never heard of a breach like that either way. I would really be worried about coolant in the transmission more then tranny fluid in the radiator. The odds of you getting a bad Radiator with the same problem are astronomically remote.. I might pay for a professional flush and just to be safe I would probably change the transmission fluid to.
Last time the Degas tank was over flowing with fluid and it was very heavy and thick. Now all seems stable, but not quite right. I’m wonder if there was some left in the lines that didn’t get flushed.
Thank you for the reply. I will look into a flush for both transmission and radiator, really frustration at this point in the project.
I was hoping it would be fixed when I replaced the radiator and drained the transmission.
No Jet the level has not changed just the viscosity has changed the color. From I’ll call it for a lack better term red to pinkish in color. After installing the new radiator I took the truck for a ride about 5 miles in total and check to see if I had the same problem.
Flushed radiator by pulling out drain plug on new radiator unit also removed block drain plugs as well. Flushed system with unit on several times. Once I seen clear liquid coming out stopped unit and let unit drain out. Did this a few times and drove around my block. Once back I checked degas bottle seen pink fluid in unit. I went to shop got a bottle of radiator flush and flushed unit again following the steps above.
