Put a 351 engine in a 06 F150 King Ranch?
This begs the answer to the question... WHY? Someone steal your engine and you have no money to buy another and you found this one along the side of the road??? I can't think of any other reason to want to do that. Get a little help from God and you might be able to make that happen, otherwise I'd say out of the question. Anything IS possible, but I'd say that's about as close to the "IM" part as you can get.
Be a lot of work, probably not legal depending on where you live, don't think you would like it when you were done anyway.
For what it would cost to try you could end up with a much better setup sticking with your 5.4 and either going to a 4v setup or maybe putting a 3v v10 in it. The modular engines will make way more civilized horsepower easier than any of the older iron.
on
So a V10 would be a better bet? I want more power. Does anyone know of a book that tells you what engines fit into a 2006 F150? I've been looking online without much luck.
Thanks guys. I'll look into a blower kit for an 06 5.4L.
Tallyho! Found an Edelbrock E-Force belt-driven blower kit for an 06 F150 5.4L 4x4. Ten pounds of boost
ought to do it.
ought to do it.
