problem,2006 5.4 lean codes,no power
Old Apr 23, 2012 | 05:18 PM
crankysam's Avatar
has anyone had this problem.Engine idles fine.no miss fire,rev's ok sitting.Has no power when pulling or when accelerated.Poped back once. checked vacuum and is ok.Truck has fuel pump driver system.
I hear they are bad for blocked cat's.?? Or maybe fuel pump going .??
any idea's...thanks
Old Apr 23, 2012 | 06:26 PM
nu-supercrew's Avatar
What codes? Maybe it's the Fuel pump module back by the spare tire?
Old Apr 24, 2012 | 08:22 AM
crankysam's Avatar
thanks for the reply nu-supercrew.scaned again,codes 0171,0174,generic codes0060,2195,2197,2272.....But also 0191 which comes up on my scanner as fuel rail pressure A cercuit.Being the first codes deal with lean condition and the 0191 deals with a fuel pressure problem,I think it could be faulty fuel pump.The truck has 200,000 K,s on it.Do you agree this maybe the problem ?.....I don't have a fuel pressure gage for this type of vehicle.....thanks Sam
Old Apr 24, 2012 | 08:37 AM
with that many miles.....
could possibly be a vacuum leak or the o2 sensers
some easy maintenance to do first is clean the maf, tb, and change the fuel filter....there are threads in the how to section of the forum on these.....
Old Apr 25, 2012 | 01:29 PM
crankysam's Avatar
thanks 88 racing.Checked all hoses and no leacks and I did change the fuel filter.Because of the fuel pressure code and the time frame I have ,I'm changing the fuel pump today..Will let you know the out come....Sam
Old Apr 26, 2012 | 10:32 AM
At that mileage, I'd change the FPDM before going after the fuel pump. Betcha it's pretty corroded. THAT is what controls fuel pressure.
Old Apr 28, 2012 | 12:39 PM
crankysam's Avatar
Ok,changed fuel pump and truck has way more power and doesn't fall on its face going up hills anymore.Lean codes are gone and fuel pressure code gone.Scanned it again and shows faulty heated o2 sensor ,bank 2,sensor 2.Also #8 cyl. random misfire.Plugs hasn't been changed for 200.000 k's.Now the fun starts.QUESTION.when they say bank 2,which side is it?:o..A friend mechanic said it is the right side. But I think it is the left side because #1 cyl. is on the right side,hence bank #1...
Old Apr 28, 2012 | 02:04 PM
ParnAZ's Avatar
Bank 1 is passenger side, bank 2 driver. Bank 2 sensor 2 is downstream sensor behind converter driver side. #1 cylinder is on passenger side
4 8
3 7
2 6
1 5
B1 B2
Old Apr 28, 2012 | 02:21 PM
MGDfan's Avatar
Why did you leave the plug change for so long?
For recommends 60k miles (100k km) now.
Poor truck. These things need proper maintenance to stay reliable and run properly. You neglect some things - the result can be cascading failures - and far more needless $$$ spent to reward you for yer lack of care.
Difficult to take you seriously when you neglect something this basic.
Front O2's are long past due as well - may as well replace the rears while yer at it.
What else have you neglected?
Here's some info - just for you:
https://www.f150online.com/forums/20...e-up-time.html
https://www.f150online.com/forums/20...ht=maintenance
There is a lot more like those - but you'd actually need to use the Search function .. I'm not holding my breath on that one ...
Preventive maintenance > Reactive maintenance.
MGD
Old Apr 28, 2012 | 10:54 PM
crankysam's Avatar
Not my truck guys. A nurse owns it..you know drive it till it drops..lol..I'm just doing the work. Thanks ParnAZ,just as I thought. Wait till the bill comes for the Plugs!...Thanks everyone for the help and yes I am going to try to pound maintanance into her head......cheers Sam
Old Apr 28, 2012 | 10:56 PM
Did you/they check the catalytic converters yet?
Old Apr 29, 2012 | 01:14 PM
DewserB's Avatar
TRUCK OF THE YEAR 2013
Ooooo....me likey how this story line plays.
Just kiddin'! Couldn't resist!
'Wait till the bill comes for the plugs'...LMAO!
Old Apr 30, 2012 | 10:59 AM
crankysam's Avatar
Let you know how that goes...Lisle makes a tool for pulling old broken plugs...I'm thinking
my customer is going to buy me an early X-mas present....ROFLMAO...
