help with f150 ( 1997 ) 4.6 v8
Old Sep 20, 2011 | 04:29 PM
jbrew's Avatar
Originally Posted by camaro77
ok i have just been out to my truck and it was set on floor / def hope this helps
Defrost runs on everything except for the "vent" setting.
Old Sep 20, 2011 | 04:34 PM
jbrew's Avatar
That's what keeps the compressor from locking up, for those who don't use it all that much.
Old Sep 20, 2011 | 04:41 PM
camaro77's Avatar
ok i dont have a vent on mine ? here are the settings on mine
max a/c
a/c
panel
off
panel and floor
floor
floor and def
def
so which one can i put it on to see if it stops it leaking?
Old Sep 20, 2011 | 04:47 PM
jbrew's Avatar
max a/c
a/c
panel
off
panel and floor
floor
floor and def
def
I meant "Panel", -my fault. :o
Old Sep 20, 2011 | 05:09 PM
ParnAZ's Avatar
Panel will not engage the a/c, use that one. Dont confuse defrost and heat it simply turns on the a/c and blows it onto the inside of the windshield/screen. The a/c pulls moisture out of the air and dries things out hence why defrost clears the "fog" off the glass. With the setting on panel there is no a/c engagement and reason for the drain to....drain. I see that you are in the UK where the relative humidity is very high and why so much dripping occurs.
Old Sep 20, 2011 | 05:15 PM
jbrew's Avatar
I already said that
Old Sep 20, 2011 | 05:17 PM
jbellows45's Avatar
i had this problem it was the defrost
Old Sep 20, 2011 | 05:19 PM
jethat's Avatar
Originally Posted by jbrew
Thought for sure it was a joke. You joined a very good Ford Truck Site, -the best IMO, with a chevy for a user name.
Just sayin.
Like no one around here hasn't ever made the camaro mistake.. I myself had 4 of them before I saw the light..
Old Sep 20, 2011 | 05:35 PM
camaro77's Avatar
hey, thanks for you helps guys i have set it on panel now, i will see what happens in the morning, and as for our weather it just rains and if we are lucky it justs rains a bit lighter,
Old Sep 20, 2011 | 05:40 PM
camaro77's Avatar
hey...the camaro is a good car, or should i say a good entry level car my son has a 25th anny model....its his pride and joy but i suppose a camaro in the states is a very basic car ??
Old Sep 20, 2011 | 06:58 PM
jethat's Avatar
it depends. The Camaro's the general sells now wouldnt be entry level. None of them. in the 80's GM sold some of them as entry level cars. V6 and I think they even had a 4 cylinder one. Like I said I had 4. A 75 type LT an 85 Z-28 an 86 Z-28 and an 86 coupe. There ok. I like Mustangs better now that I've had a couple of those..
Old Sep 20, 2011 | 07:02 PM
jbrew's Avatar
I purchased one of those once. Right out the show room. The last Iroc Z made in 1990.
Old Sep 20, 2011 | 07:28 PM
jethat's Avatar
I like the 92 Z-28. Almost bought one. The last decent Camaro until they came out with this recent one. the 93 on were ugly as sin. Went to the chevy dealer to look at it and could not believe how nasty it was. Looked like a fancy Saturn..
Old Sep 21, 2011 | 09:35 AM
Cado4570's Avatar
if it was wet on floor pan, could be a heater core problem? but you said you weren't losing antifreeze?
Old Sep 21, 2011 | 04:56 PM
camaro77's Avatar
hey guys, set my controls to ( panel ) this morning and NO leaks .... thanks fo rall your help
