500 rwhp 5.4 build ?????
Here is the deal, Im starting to buy parts for my winter project of rebuilding my procharged 5.4. As soon as drag racing is done Im getting started on buying parts. Ive read that my truck, 2001 crew cab 4x4 f150 came from the factory with a forged crankshaft............the same one that came in the superhcarged lightning thats supposed to be good for 900fwhp? Is this fact or just BS, if its fact great I just saved myself some $$$.
Other parts Im going with are Manley 4340 rods, 10.1:1 pistons (procharger's recomendation). Sending the heads off to get a stage three port job, Lunati blower cams and valvetrain set up, 12 psi pully for the procharger, fuel system to support it built with the stock block and a custom tune.
Thanks.
Thanks.
im very interested in this also... my 5.4 has 198k miles on it and i wana rebuild it. ill be off to college next year and after college military so my trucks not gonna be a dd after this year and i want to tear it down to the block and rebuild and make some serious hp.... def. will be keeping a eye on this. are you 4x4 and do you still have stock tranny?
Stock block 500hp? Why?
If your planing on making big HP, go with all forged internals! Crank ,rods and pistons.
There is a good chance your truck already has a forged crank (my 03 5.4 came stock from the factory with a forged crank) But it was kinda hit and miss what 5.4s got them. So you have a 50 50 chance on it being forged.
With 12 PSI you might hit 500 HP but not 500 RWHP.
Good luck, sounds like fun.
Ive built multiple 1000+ hp sbf nitrous motors for drag racing and Im currently building a 600 hp pump gas 408 for my buddy's 92 notch also........bet it clears 600 in N/A trim also on 93 pump gas and is very streetable.
And no Im not d**k mesuring with you or trying to come accross as a *****, you may be right but lets just wait and see what it does.
My baby
on
SFB- SBF whatever.
Small block Ford, spell it out and I'll know what the hell your talking about.
You can make a ton more power with a small block Ford then you can with a 5.4 Triton just buy porting the heads and bumping up the compression.
5.4 is a totally different animal. You need a power adder,and if you hit 500HP,not RWHP your lucky with 12 PSI.
I have most of the same mods ,and I was running 15 PSI before I ever broke 500RWHP!
