P0022 Error Code Help?
Old Jul 12, 2011 | 07:59 AM
rogue7a's Avatar
Exclamation P0022 Error Code Help?
I have a 2008 F150 4x4 Super Crew 5.4L Triton w/ 45k miles and am having some issues.
I changed the oil, filter and air filter this weekend and as usual ran the truck for about 10 minutes to check for leaks which there were none. After driving on the highway I stopped at a toll booth and the RPMs dropped and the truck shook. I immediately pulled over and checked the oil level etc which was still normal. Fearing that I had not put the proper oil in I changed it again and still had the same issue. I got home, disconnected the battery for a few hours and fired it back up. Ran fine for about 20 minutes but rough at low RPM’s or when I stop. Placing it in neutral and briefly increasing the RPM’s seems to clear it up for a moment. The Check Engine light finally came on and the Error code is:
P0022 Intake cam timing on bank 2 over retarded
Last night I replaced the cam position sensor on bank 2 and the truck is doing the same thing. What else am I missing here?
Old Jul 12, 2011 | 01:15 PM
Confirm that you changed the sensor on the driver's side - that's Bank 2.
I'm guessing that the driver's side cam phaser may be stuck or inoperative - it runs on oil pressure and it has a screen that may be plugged up. Any possibility the engine is sludged up due to improper maintenance? What exact oil and filter are you using?
Old Jul 12, 2011 | 02:28 PM
rogue7a's Avatar
Valvoline 5w20 synthetic and a Fram filter. Yes, I changed the position sensor on the drivers side (Bank 2). I ordered another VCT from Ford today and will pick up this evening. If that doesn't work, what is my next step?
Old Jul 12, 2011 | 02:36 PM
Getting rid of the fram oil filter and getting a motorcraft one.....maybe that will help a little
Edit get a VCT solenoid that could be the problem....
Old Jul 12, 2011 | 08:42 PM
jbrew's Avatar
Yea, stay away from that Fram, = search ("Orange can of Death").
Old Jul 13, 2011 | 10:14 AM
rogue7a's Avatar
What is the secret for removing the valve cover? Plugs are out all cables are removed, removed the power steering reservoir bracket (That was genius attaching it to a header bolt... not)
Old Jul 13, 2011 | 10:38 AM
Um....you don't need to remove the valve cover to get the VCT out.....
http://www.fordtruckclub.net/forum/s...ead.php?t=4066
Old Jul 13, 2011 | 10:52 AM
rogue7a's Avatar
On an 08 5.4L Triton, Drivers side you do
Old Jul 13, 2011 | 10:53 AM
rogue7a's Avatar
Now if it was an '04 like in your link, I would've been done in 20 minutes
Old Jul 13, 2011 | 11:05 AM
So if im understanding this correctly....the 08 3v head when it got revised for the better plugs. The VCT also was changed on how its installed and are the part numbers the same from 07 to 08?
I thought all 3v heads were the same as far as, compononents the only revision was the plugs.....
Old Jul 13, 2011 | 11:41 AM
rogue7a's Avatar
The seal on the earlier models is bigger.
Now, what is holding up the cover?
Old Jul 13, 2011 | 12:09 PM
DYNOTECH's Avatar
Two dabs of RTV at the front of the cam cover right where the front cover cam cover and cyl head meet. Its just under the cover at the gasket. The RTV seals the joint from oil seepage and will hold the cover down making it hard to remove. Use a sharp narrow putty knife to cut through the RTV.
Old Jul 13, 2011 | 03:07 PM
rogue7a's Avatar
No, actually removing it. It's free, I just cant get it to come forward. It's sticking on something
Old Aug 17, 2011 | 03:48 PM
wdbarnhill's Avatar
Hey rogue, did you ever get your truck running>>> Was it the VCT Selinoid?
