5.4 F150 3 Valve looking for master technician
Hi Everyone
I've been reading all of the wonderful posts regarding the spark plug removal. I've called many gargages in CT and can't seem to locate someone who is versed in the process of removing the plugs or maybe they just don't want to. I would go to a dealer but they have already quoted me 2,500.00 which is an exhortant amount of money.
I am looking for a garge in CT, hartford county, where I can bring my truck to have the plugs replaced. It is a 2007 F150 5.4 3V with 91,000.00.
Heather
Heather
Plug changes
For that, you could drive to Mn and have my mechanic do it for alot less. Had mine done the other month early cause I wanted the 2 piece plugs out. All came out intact and cost me $200 including the replacement plugs.
If nothing else, see if you can find an ASE certified mechanic and go have a talk with them. Good luck
Here in the Detroit area the Ford dealers charge $320.00 to change the plugs plus if any break its $100.00 to remove the first plug and $50.00 for every broken one after that. I charge $50.00 for removing each broken plug. I've removed 19 broken plugs so far. Just an idea what others are paying. A couple auto parts stores have my phone number and hand it out to customers that are looking for help with these. You might want to try asking around. Good luck.
Brew it's mis-spelled (my specialty!) the word is exhorbatant (that's as close as my phonics will get me) it means way too much, like way overboard.
Wow! I did that without a dictionary, shows what you can do when you burn through a 2 year collage in 5 short years! And I'm proud of that.
(your specialty? )
I spent a $80.00 on plugs, $90 on Lisle Tool and $35.00 on one COP. and a day and a half worth of my time. I did all the labor by myself. I watched a 6 minute tutorial on youtube and did it!!! All the postts I read on here gave me the heads up on so much, so thanks everybody.
