Spark Plug HELP!!
Spark Plug HELP!!
ok.. so i'm changing the spark plugs (again)
do to super charger install..
all but one came right out with out any trouble
the on is is stuck bad,, the hex is striped but still tight and
i can not get it out..
what do you think i should do from here
i had two thoughts..
i finish install and just start truck untill its warm, then try to remove the
plug..
or
use some tool and break up the porclin then maybe use a needle nose plyers
to remove the hex (or use the lisie tool)
any help
its soaking in bP blaster as we speak! (please help)
thanks
plug..
or
any help
thanks
plug..
or
any help
thanks
plug..
or
any help
thanks
Although I am a fan of PB Blaster, I used a product called ChemSearch “Yield”. The issue I have with using carb cleaner is the lack of lubrication…..in the old days of removing steel plugs from aluminum heads, we use to mix up acetone & ATF…or of we needed more lubrication, kerosene & ATF, “Yield” provides this lubrication- much better IMHO than even PB Blaster
Stuck Plug
I've not heard of the hex rounding off on a plug except when it's tight and someone used a 12 point socket or wrench on them (in old days). If there's a chance you did this, do you have a 6 point socket you can try?
I've seen reference to these, but I don't have any so I've not tried them: http://www.bt-andf.com/
Apparently they may have some for sparkplugs also: http://www.bt-andf.com/products.php
Good luck
Good luck
