Motor swap in progress...4.6L is OUT!!!
Old Feb 13, 2011 | 11:34 AM
mxr181's Avatar
oh believe me we hit that thing hard! we put some PB blaster on it ahead of time and still were not able to get the damn thing off! I am really hoping I can get my hands on a set of the right tools to get it off and they let me pull the stupid thing off! ok gotta get back to work!
Old Feb 13, 2011 | 11:39 AM
autozone "rents" the tools for 20 bucks and refunds your money when you return them. Or just hang onto them because its low cost for a decent tool
Get the set listed for the old ford 4.9 I6
Old Feb 13, 2011 | 11:43 AM
mxr181's Avatar
thank you pat...I was actually just about to call them!
Old Feb 13, 2011 | 01:09 PM
shifty_85's Avatar
shoulda pulled motor and trans out at the same time and put them in. we did it 3 times in my buddys expy.....hes not allowed to own triton motors any more....
Old Feb 13, 2011 | 07:59 PM
mxr181's Avatar
THE 5.4L IS IN FINALLY! It has been a bit of a fight but its now sitting in its new home...I rented the fan removal tools and even got a huge cresent wrench and we still were not able to get the stupid fan off! we finally said screw it and shoehorned it in with the fan on and it really wasnt even that bad!
Old Feb 13, 2011 | 08:05 PM
mxr181's Avatar
I am trying to search for it, but does anyone know off the top of their head if the knock sensor under the intake runs out the back or the front? I dont have the engine harnes in the truck yet and I want to get the intake manifold back on but cant remember how that was routed.
Old Feb 13, 2011 | 08:18 PM
five0merc's Avatar
I do believe the back. Don't quite me though seeing how I have no access to a ford right now. Haha
Old Feb 13, 2011 | 08:19 PM
shifty_85's Avatar
i wanna say the front my buddys expy all those motors seemed to run out the front if i recall.
Old Feb 13, 2011 | 09:12 PM
Toyz's Avatar
Was just going over some pics of my swap. On the 00 5.4L that went in, sensor is toward the front and wire runs to the back.
Old Feb 13, 2011 | 09:40 PM
mxr181's Avatar
thank you guys...Toyz mine is a 2000 also...the sensor is middle / towards the front and it looks like the wire runs back, atleast thats the way I did it, I guess I will see once the harness goes in
Old Feb 13, 2011 | 11:07 PM
JMC's Avatar
JMC
25 Year Member
The wires for the knock sensor come out the back. The only wire coming out the front is for the CHT (cylinder Head Temperature) sensor.
Old Feb 13, 2011 | 11:45 PM
Toyz's Avatar
You can see it here. And the CHT sensor (white) if you look hard enough, its a messy pic.
Old Feb 14, 2011 | 12:56 AM
mxr181's Avatar
perfect! thats exactly how I did mine...do you mind posting a couple more pics with it more complete, I would just like to compare my routing of various lines / connectors to yours if you dont mind. THANKS!
Old Feb 14, 2011 | 01:19 AM
Toyz's Avatar
I'll see what I can dig up. A lot of my pics are close ups for particular areas that I was concerned for everything to go back together. To be honest, I never had to use them. It's one of the most simplest wiring and vacuum layout I have seen. Other than the injectors and cop's there really isnt much, only a few sensors.. and most of the wiring harness is already pre shaped to go in the areas where they go so once its on, it speaks for itself. Same with the vacuum lines for the pcv system and such, they are pre formed and go right back into their perspective areas. Hardest to reach will be your upper 02 sensors. Mine were still attached to the back of the heads which made it easy to plug back in since they were stationary. I have lots of pics though so if theres a particular area you want to know about, I'll look around.
Old Feb 14, 2011 | 02:39 AM
five0merc's Avatar
^^^Agreed!! The wiring harness and vacuum lines just fall into place on these. They are probably one of the simplest to get wired.
