WTF is this?? HELP!!
Old Nov 7, 2010 | 09:38 AM
f150fella08's Avatar
somebody accidentally put a supercharger on there and didnt tell you!!
Old Nov 7, 2010 | 11:31 AM
fine_style150's Avatar
Originally Posted by JimmysotherFORD
bingo, we have a winner...... i knew a heard that sound before chang out your idler pully and tensoner pully and the sound should magically go away.
my dealer is open today for those fellas who need oil changes and the likes so i took it in and got an appointment for tommorow, service advisor said its probably the tensioner pulley..i dont know squat about this stuff period so we'll see, and they said that most likely its covered since its still under warranty.
what i do know is all my gauges are fine, the dash says nothing wrong so far and the system says everything is ok including the electrical, my bass amp is only a 750 watt mono so i would not see how that could mess up the alternator-besides some bearing failure due to normal wear and tear on 23000 miles?? who knows.
Old Nov 7, 2010 | 11:33 AM
Originally Posted by Toyz
X2
Sounds like my alternator when the bearing went out. Fool your friends and tell them its a supercharger
Mine would turn into a really high pitched whine at high rpms
idk man the supercharger sound sounds cool at high speeds, this thing creeps me out at full throttle tho since i know there isnt a supercharger under there
Old Nov 7, 2010 | 12:32 PM
jbrew's Avatar
It does sound like a roots charger lol. fine_style150, you can tell for yourself what it is. Well, -if it's the alternator or tensioner anyway. Just stethoscope it with something laying around in the garage real quick. A long screw driver would work or something solid, like a long thin piece of pipe or rod stock. Use that to probe, with the opposite end to your ear. When you find the culprit, you'll know it. You'll be surprised how good that works, - I bet you find it within 5 minutes or so. Check the idler pulley as well (by the tensioner).
EDIT DAMN! Labnerd already posted this or similar, I missed that post, my fault. -But yea, use whatever, it works well, if you can't wait until tomorrow that is.
Hell, I can't wait, - so go do it right now lol.
Old Nov 7, 2010 | 06:26 PM
Haveme1's Avatar
It's not coming from the speakers is it ?
I found the heat shield rubbing the front drive shaft yesterday. Something like that would have me searching all over where the sound was coming from.
I found this while reading ..... https://www.f150online.com/forums/su...end-whine.html
Post the answer
Old Nov 7, 2010 | 06:34 PM
sounds more like PS to me then Alt, but ive been wrong before.
I know ford makes a synthetic fluid that you can drain and fill the PS system, should help, since the factory uses plain ATF as PS fluid
Old Nov 7, 2010 | 07:03 PM
Longshot270's Avatar
Post the answer
I was thinking speakers as well but it seems too loud for that. The tone is also off to be that. Sounds mechanical.
Old Nov 8, 2010 | 01:07 PM
got the truck back i took it in myself and the problem was a pulley, the one located on the right bank if yah look at it from the front, sits to the side of the oil filter, reason i know is cuz its the cleanest pulley out of all the other ones. they did not giove me a receipt since it is under warranty apparantly theyre going to mail it in -___- anywho i think it was a tensioner pulley it juist sits there and theres really not much goin on with it its just strapped to the block- heck thats how much i know about engines
i can actually hear my stock exhaust again
Old Nov 8, 2010 | 01:08 PM
btw thanks alot for your posts guys i learned alot thru all of this
Old Nov 8, 2010 | 02:48 PM
DarkShadowSTX's Avatar
Good to hear your truck is fixed.
Old Nov 8, 2010 | 02:51 PM
shifty_85's Avatar
edit: glad to hear its fixed!
Last edited by shifty_85; Nov 8, 2010 at 02:52 PM. Reason: im dumb and didnt read his posts
Old Nov 8, 2010 | 06:33 PM
jbrew's Avatar
Which one exactly? lol -
Old Nov 8, 2010 | 10:31 PM
shifty_85's Avatar
well brew its either 4 5 or 6 if its on the right bank maybe ever 7
jeeeez can they put any more pulleys on there?????
Old Nov 8, 2010 | 11:00 PM
jbrew's Avatar
- your not kidden lol.
Iduno, - neither does he, that's terrible. He should have just told us what the work order said. Oh well, -blows.
So it's either the idler, - or it was the pump after all. Oil filter ? That's right behind the pump, but if that was squealing, -seems like they should have replaced the pump. Iduno, -screw it.
Old Nov 9, 2010 | 06:15 AM
Yea really. Wait until he has to figure out which one it is the next time one goes out.
