What is wrong!!!
Old 09-22-2010, 09:16 PM
kingkong911's Avatar
What is wrong!!!
MY truck is throwing a trouble code P1151. Its slow as hell right now 0-60 12 seconds! my fastest was 6 a few months ago before my lift could the lift slow it down this much? But what do i need to get to get this fixed
Old 09-22-2010, 09:34 PM
Labnerd's Avatar
A code P1151 may mean that one or more of the following has happened:
Electrical:
Short to VPWR in the harness or HO2S
Water in the harness connector
Open/shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system:
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam Timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
Old 09-22-2010, 09:36 PM
chiefFX4's Avatar
what year and engine is the truck? might help track things down a little better.
Old 09-22-2010, 09:52 PM
dirt bike dave's Avatar
Well, he says it used to do 0-60 in 6 seconds before he lifted it, so he must have dropped in a Lightning motor.
Old 09-22-2010, 10:24 PM
2007 f150. i have the picture to prove it ive done quite a bit of engine work to my truck. You might wanna know just whats under my hood before you talk that trash
Old 09-22-2010, 10:30 PM
I have ported heads, comp cams, with a pro street stroker kit...
Old 09-22-2010, 10:38 PM
Whats weird is my motor kinda sounds like a diesel when in the engine compartment i dont know if thats normal or not i have not listened to another f150 with 4.6l.
Old 09-23-2010, 04:06 AM
code58's Avatar
Did you get ahold of the green handle at the gas station??? That's probably why it sounds that way. You feed it diesel and it's gonna act like one.
Old 09-23-2010, 12:19 PM
haha if that was the case i think everyone and their grandmother would be putting diesel in their tank haha i kknow i sure as hell would. BLACK SMOKE with the f150
Old 09-23-2010, 12:26 PM
offroadn'98's Avatar
Prolly bc you have cams, prolly chops pretty good. The 4.6 is just a quite lil motor.
Old 09-23-2010, 12:54 PM
JasonFX4's Avatar
Thats what happens when you mess with something a guy with a PHD in engineering designed! You could take it to the dealer, but you'd pay because you voided the warranty. Did you do all of that work yourself or did you take it somewhere?
Old 09-24-2010, 06:01 AM
#1 when you added the lift and larger tires, did you regear it??
#2 get the eletrical issue sorted (the code)
#3 I assume you have a 4.6 that's been stroked??
#4 who did the tune for you?
#5 what's the entire mod list??
Old 09-24-2010, 08:54 AM
JMC's Avatar
JMC
JMC is offline
Details on engine year etc please. The way I understand things is you lifted the truck a few months ago and it slowed down. Now a P1151 code showed up and you are posting because of this and adding the performance complaint. If that is the case then there are two issues. If they both appeared at the same time it is one issue.
Old 10-10-2010, 09:10 PM
05crewzer's Avatar
just a couple thoughts.
1) how loud is the "diesel" sound, could it be the ticking of the injectors or cam phasers?
2) was part of the lift a body lift? did something electrical get pinched or stretched?
3) saying that the code issue got fixed, i agree with above and gears need to be addressed. i went to 35's and stock gearing and it takes a bit longer to get into the power range!
oh and how high did you go?
Old 10-11-2010, 05:49 AM
I think the OP is long gone fellers
Quick Reply: What is wrong!!!
