F Me Running
F Me Running
need to figure out why my injectors arent pulsing......replaced pcm and that didnt help.....i have enough pressure at the rails from the pump but the injectors arent pulsing.....anyone have some ideas? it will start up if i put starter fluid though the intake.
Need more info, - what led to this? What is the rail pressure? Have the injectors been purged ? The PCM has the ability to shut the rail down, but there's usually an easy explanation.
Also, fill your info in. You not giving us squat to go on. We aren't mind readers, what are you working on ?
2000 f150 4.6
car will turn over but not start
checked fuel pump-its fine
replaced fuel pump relay
replaced pcm
starters fine, batteries fine
my buddy did the diagnostic work with his tools and fuel pressure is fine, the fuel injectors are not pulsing like they should
he sent a charge to one of the injectors and it has the ability to start up with power going to it
not sure if theres a separate relay for injectors but that could be a possibility
replaced pcm
You aren't going to get good help if you keep opening new threads - this is the 4th one. Brew doesn't have a CLUE what the background is, and he has better things to do than chase down the other 3 threads.
I had a similar issue in my 5.4 , u either need to purge and clean the injectors as stated above, or replace them like i did and u should be good to go, mine took me a while to figure out as well, but engine sat too long and gummed up the orifices!
Good luck!
Good luck!
yea its just weird i drive the truck every day so idk why the injectors would get gummed up......i'll check em out tho thanks
Right, I wouldn't answer any one of his fricken questions without knowing what led up to this. It's probably something very simple, but if he can't help us to help him, - screw it... He's going to keep asking questions that have nothing to do with it until he finally clues everyone in on HOW all this started.
BTW- It must be one hell of secret what really happened here lol.
Not that I care, it's just ridicules, -among other things. It's not worth the effort glc .
Did you see this man, Steve already helped him out -
https://www.f150online.com/forums/v8...-question.html
What an A-Hole (the OP).
pizzlehead44, welcome to the ignore list.
glc, -did he start more threads other than these two?
