Spark plug wont come out
Old May 10, 2010 | 02:30 PM
fritz4077's Avatar
decided to change the plugs today and i get to the third one of the drivers side of the block and it loosened it but it keeps spinning....i tired using needle nose to get it out and nothing...i dont think it will even screw back in...how do i get this plug out...and its an 01 Lightning
Old May 10, 2010 | 03:14 PM
Toyz's Avatar
Sounds like it might have spun the aluminum threads out with it? Hope not Cant think of any other reason it would freely spin and not come out. Either way.. Not quite sure what to do. Might have to rig your plug socket to hang onto it real good, apply a little upward pull while your spinning it.
Old May 10, 2010 | 04:07 PM
fritz4077's Avatar
damn is that possible it wasnt a pain the loosen either just like all the other ones...
Old May 10, 2010 | 06:26 PM
DYNOTECH's Avatar
Are you positive that there is nothing in the hole keeping the socket from completely engaging the plug making it feel like its just spinning? If not then more than likely the threads are stripped now. Might try cranking it over and blow the plug completely out. Then get a timesert to replace the threads.
Old May 10, 2010 | 07:06 PM
fritz4077's Avatar
so if i turn it on it will just blow out of the motor sounds bad for the motor haha
Old May 10, 2010 | 08:17 PM
fritz4077's Avatar
where do i buy this kit from
Old May 10, 2010 | 08:41 PM
Rent it from a member here. Galaxy
Old May 10, 2010 | 10:18 PM
fritz4077's Avatar
ok thanks man i just PM'ed him
Old May 10, 2010 | 10:21 PM
He has helped many. Good luck with getting it fixed.
Old May 11, 2010 | 11:36 AM
Don't rent it till you DO get the plug out and see exactly what's going on.
Old May 11, 2010 | 10:56 PM
chiefFX4's Avatar
you really should see exactly what's going on before renting the kit. did you scrape around the plug holes then run in there with compressed air first? might be some dirt not allowing you to get a full seat on the plug.
if you do need the kit, galaxy will hook you up.
Old May 11, 2010 | 11:32 PM
fritz4077's Avatar
no i didnt have a chance to work on my truck today due to it rained all day long....but i dont think its dirt cause it just spins but its always worth a try
Old May 12, 2010 | 06:12 PM
tim98's Avatar
Don't crank the ENGINE!! If the threads are stripped you may have shavings in the cylinder. This will make it worse in the long run!
Old May 12, 2010 | 07:50 PM
DYNOTECH's Avatar
Just my opinion but I think the risk is small that the possible minute aluminum shavings will create a problem. Just not sure what other option he has to remove the stripped plug short of pulling the head. The risk of screwing things up pulling a cyl head are far greater.
Old May 12, 2010 | 09:27 PM
Toyz's Avatar
Try to fab something up with plug socket that grabs the top of the plug, that way you can pull while your turning.
