Need help/advise
Need help/advise
I have a 97 4.6L with 172,000miles. On my way home from work she started shimmering and shaking then the check engine light was blinking like 50 times then went steady for a while then back to blinking. The whole time she is shuttering kinda bad. I stopped at Autozone to get a code they said it was a "number two missfire". I don't know much about these motors. Is this something I can do myself? I'm handy just not used to working on modular motors. I was told to pick up a coil pack and plug. Is that right? Hope I don't sound like a idiot. I just don't have extra $$$ right now I'm hoping I can do it and save some labor $$$.
Basicaly I'm asking if you think from the Autozone dignose of a number two missfire would you agree it's most likely a plug and coil pack? If yes, I was told the order from the front of the engine looking towards the back of the truck was:
8 4
7 3
6 2
5 1
If this is correct the plug is accessable and I know I can replace it myself. Is there anything I should know to do this job or is it just pop it out and pop the new one in?
any info would be great, thanks in advance.
8 4
7 3
6 2
5 1
when was the last complete plug change? probably time to do that. get motor craft plugs Rock auto has them for about $4 each. Replace all the coils for the price of one here..
http://cgi.ebay.com/ebaymotors/NEW-I...item5886071f9e
8 4
7 3
6 2
5 1
8 4
7 3
6 2
5 1
back
4 8
3 7
2 6
1 5
front
This is the correct pattern, #2 is the second from the front on the passenger side.
I also have to appologize before I get slammed here. I just did a search and this had been covered many, many, many, many, times... I was just flustered due to that I dropped over $1,000 into her in less than two weeks on general maintenence stuff. So sorry and thanks.
Thanks that was perfect...
Rockauto.com
I ordered the plugs and wire set from http://www.rockauto.com/ just now it was $108.00 shipped 3Day Express (It would have been $98.00 ground but I can't wait that long).
Thanks again for all your help. Now I just have to borrow a tourqe wrench to properly install them. thanks again.
1997 4.6L F-150 4x4 extended cab
jethat gave me this link http://cgi.ebay.com/ebaymotors/NEW-I...item5886071f9e and has a part number of DG491 / DG508. That part number conflicts with glc's part number DG530. I need to know the correct number so I can try and get her running right again. Thanks guys.
