3.0 Tauras starting prob.
Fuel pump wont run, car just spins over. I hit it with starting fluid, it fires right up. Let it run for a few, shut it off, key on, then the pump will run just fine and car will start every time. No power complaints, just after sitting over night, the pump will NOT run until forcefed with the good ole "e"
Are you sure it isn't just losing it's prime?(so to speak) Did you try turning the ignition switch off and on about ten times before trying to start? This wouldn't help if you don't hear the pump run for a second or two each time the switch is turned on. Just a thought. I'm just curious, What year is your Taurus?
