Trying to get to 400hp?
You're pretty much dreamin if you want to get to 400 without a blower in these trucks inless you have cams and heads. I have pretty much every bolt on minus under drive pullies and trust me I am no where close. I have an S&B, pacesetter longtubes, highflow cats, true duals, E-fans, and custom tunes. My truck is a lot faster but it's still a dog. Next for me is bigger injectors, fuel pump, and procharger
400 at the wheels or at the crank? They say the 5.4's are 330 at the crank stock getting to 400 at the crank should be doable. Long tube headers=30 hp edge=15 that gives you 375. a few more odds and ends could put you over 400. 400 at the wheels is an entirle different story. No way to do it without forced induction. You would need about 525hp at the crank to make 400 at the wheels.
Noone likes hearing this, but why not a 100hp shot of NO2? If you do it right, with the right module. You can enter in, digitally, all your trip points, alarm shutoffs, etc.
Running a 100hp NO2 will not only get you there, but you wont be there unless you need it. Of course, it does require new nozzels,et al.
Worth looking into though.
