My 5.4 swap
Old Nov 10, 2008 | 11:10 PM
  #121
JMC's Avatar
JMC
25 Year Member
Originally Posted by Camarothatcould
COOLANT HOSES!!!!!
The coolant hose that came with this motor has the fitting between the hose assembly, it runs to the oil cooler. They cut the lines and I cannot use the parts that go to the radiator itself or the overflow, and idea on how to remove this middle section so I can use my oil cooler??
I've been dropped tooooo many times as a child. Pictures please. What is cut and what is not? What do you want to use and what do you have?
Regards
Jean Marc Chartier
Old Nov 10, 2008 | 11:28 PM
  #122
FRod's Avatar
Originally Posted by Klitch
sorry frod, i thought my answer was just enough sarcasm mixed in with a hint that you'd pick up on it. JMC set ya straight.
oh and 1800? *snicker*
think of how me and joey feel... youve only just begun!
haha oh i know. Because now i have a 5.4, i want boost. Well for the engine and tranny was $1200 all together, than the cai 250, headers 300, 300 in antifreeze trani fluid power steering fluid and amsoil 10w30, since the starter is such a pain i just said screw it, that was $125, new Prior power brake booster $130, new a/c condensor, gatorbelt UD pulleys, efan kit (pending) new ball joints tie rods a arms stabalizer bar links, all new u joints, Kennetic slotted rotors and ceramic pads, new vaccuum lines and hoses, gaskets, its up around $2600 now as of today since i ordered most of the stuff about 3 hours ago lol and i still have more plans, like 20 inch black corba r's on some beafy tred, then a buddy is going to do some small cut and patch body work as a side job for cheap, than its off to get painted! And im looking at a rollpan, cowl hood and a new tailgate to get painted aswell...ahh!! i really do hear you...It just goes on and on BUT i am hopefully going to be happy with the outcome, i have already gotten my moneys worth out of the old 4.6. I got it at 250,000 for $1700 bucks and now its 313,000.
Old Nov 11, 2008 | 04:23 PM
  #123
Camarothatcould's Avatar
what i want to make work, but they are cut
what i have.
I'd love to incorporate the oil cooler, but I know thats an EXPENSIVE hose from FORD. I might just put in PVC tubing, slide hoses together, than clamp them. . .
Old Nov 11, 2008 | 06:39 PM
  #124
JMC's Avatar
JMC
25 Year Member
That what I thought the problem was. So cut the plastic clamps that hold the degas bottle hose and the front section of rad hose to the middle section. Replace those hoses with some universal flexible hose from a parts store. If that doesn't suit you cut your radiator and degas bottle hose and splice them to the Navi hose assembly with something like this.
Regards
Jean Marc Chartier
Old Nov 12, 2008 | 12:22 AM
  #125
I could do that. . . thanks
Old Nov 12, 2008 | 07:49 PM
  #126
SO.... I cut off the cut hoses and splice on the exsisting hoses. . duh
Got my intake on today, ran plug wires. Just have to lay harness, alternator, belt, fluids, exhaust manifolds, cut off pre-cats, then fab up exhaust. . .
Old Nov 13, 2008 | 10:28 AM
  #127
FRod's Avatar
gittin er' dun!
Old Nov 13, 2008 | 06:54 PM
  #128
while getting the belt on , I looked at the diagram and realized that the 5.4 calls for the idler pulley that I took off early. I put that pulley on, tried to get the belt on but with the tensioner bottomed out, the belt would not reach. I took that same idler off, and put the belt on just fine. I then pushed th epulley against the belt with 0 pounds of pressure and th epulley slid right on the groove and I bolted it up . . . .WTF!?
Old Nov 13, 2008 | 07:56 PM
  #129
FRod's Avatar
Thats really wierd, is this a new belt or used belt from the 4.6 (should not matter at all) Do you have your ac and power steering attached lol? Not trying to be smart or anything, but everything is pinpoint the very VERY exact same as your 4.6, it should fit how your 4.6 fit.
Old Nov 14, 2008 | 10:51 AM
  #130
yes, its the gatorback that was on my 4.6... it wasnt binding or caught up, it just would not stretch with the pulley i place, only after the belt was on did the pulley slide right on. . . fawking weird
Old Nov 14, 2008 | 03:27 PM
  #131
THROTTLE CABLE BRACKET
um, neither of them work. . . 5.4 doesnt except cable and 4.6 doesnt fit on the manifold. . .
Old Nov 14, 2008 | 05:15 PM
  #132
JMC's Avatar
JMC
25 Year Member
Cut so both bases overlap and weld/bolt/rivet together?
Regards
Jean Marc Chartier
Old Nov 14, 2008 | 05:38 PM
  #133
Went and grabbed the cable off the Navi
Old Nov 14, 2008 | 05:45 PM
  #134
While I grabbed the throttle cable off I took some pics. . . Here's the donor
Old Nov 14, 2008 | 07:36 PM
  #135
What were the exact HP/TRQ numbers for the engine? I'm guessing its 235HP/335TRQ...
