My E-fan Build. with pics.
Old Nov 20, 2008 | 01:46 AM
  #76
Fifty150's Avatar
The second fan should get hooked up to a second switch.
Old Nov 20, 2008 | 09:37 PM
  #77
xxs0ulxx's Avatar
that light idea is sweet! i have to put that in! i think that fiftyf150 is better suited to answer your question.
Old Nov 22, 2008 | 05:24 AM
  #78
FRod's Avatar
how do i go about putting this probe through the radiator, anyone got pictures? I am going to do the strips of metal thng and NOT put bolts through my radatior, thats senseless (no offence) LOL!
Old Nov 22, 2008 | 05:36 AM
  #79
FRod's Avatar
and the a/c wire, does that get tied in with the a/c power wire? "the hot wire"
Old Nov 22, 2008 | 05:39 AM
  #80
FRod's Avatar
Originally Posted by xxs0ulxx
Above is a view from the driver side into the hood, the picture below is from the passenger side... oh and i taped the heck outta the hanging wires b/c there was nothing to run them on, so i left them hanging and when i drive through high weeds and stuff on the trails i wont pull em out.. the wires are pretty high up...
you tied both power wires and ground wires together with both fans, what did you do after that? Splice the ground with the ground on the controller, than used the controller ground and bolted it to the frame? And tied the those two fans to 1 of the fan wires?
Old Nov 22, 2008 | 11:05 AM
  #81
xxs0ulxx's Avatar
okay, i did splice the power and ground wires with both fans together, then i ran the ground wire to the frame. I ran the power wire into the controller and out of the controloer. from the controler the power wire went straight tot eh battery. My controller is breaking the powersource as long as the temperature does not meet, say, 195.. when it hits 195 deg. the the power source is flowing to the fans.
Old Nov 22, 2008 | 11:58 AM
  #82
JMC's Avatar
JMC
25 Year Member
Originally Posted by FRod
so what do you think i should do? I like the light idea i think i can pick one up somewhere, all i have to do as run it to the light as power, then ground the light right? Than what do i do with the second fan, how does that get hooked up?
How many controllers do you have? Running 2 fans on one controller is a no no, unless you are using quality kit that is designed to handle it.
Fans can draw up to 40 amps on start up. That is 80 amps running through 1 controller. I have the Troyer kit. It uses two controllers. The controllers are made by Durale. They have a second lead to power a second fan. I use that lead to turn on a light in my instrument cluster. I don't have the little PRND21 plate in the instrument cluster so I placed t lights in the blank cover. When I need to remove the cluster I just remove that plate and the cluster is free to come out. I would suggest that if you place lights in your cluster that you add connectors so that the cluster can be removed by disconnecting the connectors rather than removing the lights.
Regards
Jean Marc Chartier
PS. yes one side of the light gets power from the controller and the other wire goes to ground.
Old Nov 22, 2008 | 12:01 PM
  #83
JMC's Avatar
JMC
25 Year Member
Might I suggest rerouting the wires out of the way?
I play in the **** all the time. No worries from snagging a wire.
Regards
Jean Marc Chartier
Old Nov 22, 2008 | 03:18 PM
  #84
FRod's Avatar
If i get another controller its gonna have 4 selections for fans. This is what i think you guys are saying. Hook one fan up to one wire on one controlller, 1 on the other, but take the 2nd wire from one of the controllers and run it to a light? Than how are they both supposed to know when the a/c is on? Tie them in with the a/c unit? Do i run that a/c wire from the controller to the power lead of the a/c, and what ignition wire would you recommend?
Old Nov 22, 2008 | 09:11 PM
  #85
xxs0ulxx's Avatar
Regards
Jean Marc Chartier
good idea bro.. i will rerout them
Old Nov 23, 2008 | 02:24 AM
  #86
FRod's Avatar
Regards
Jean Marc Chartier
So you got 1 on each side in that wire loom? Did you tie the controller's a/c wires to the a/c sensor on the compressor?
Old Nov 24, 2008 | 12:29 AM
  #87
Fifty150's Avatar
Can someone please scan the Troyer Performance installation manual for this kid? He's installing the same switch on similar fans. All his questions will be answered.....wiring, probes, grounding, how not to cut his fingers, et cetera.....
Take That & Rewind It Back
Originally Posted by Fifty150
Old Nov 24, 2008 | 02:03 AM
  #88
JMC's Avatar
JMC
25 Year Member
I have two controllers each with a temperature probe and a second wire to supply power for a second fan. The Blue wire, which powers a second fan, is sent to a light in the instrument cluster. When the controller turns on a Fan it also turns on the light letting me know which fan is on. I only have 1 fan connected to the AC circuit to turn on when the AC clutch is activated. I have a master kill switch to turn off both fans for water crossings. I also have individual switches to independently turn on each fan. The switches bypass the controllers in case of controller failure.
Regards
Jean Marc Chartier
Old Nov 24, 2008 | 01:59 PM
  #89
FRod's Avatar
ouch that was mean! i am not illiterate dude i think with a little explanation i can handle it. I have just not done them before. That would be nice if someone scanned the manual for me though.
*JMC - Alright so controller A, ground it, power it, tie it to the a/c, then fan wire 1 to to fan 1, and also to a light on the dash. Than tie to ignition wire.
Controller B, ground it, power it, leave off A/C, than fan wire 1 to fan 2, and tie to ignition as well..
Correct me if im wrong.
What did you do with your fan wire 2 from each controller? Use those for the individual fans?
Old Nov 24, 2008 | 04:03 PM
  #90
JMC's Avatar
JMC
25 Year Member
I cannot find the instructions for the Troyer kit or I would send them to you. Here is a link to install instructions for the Derale fan controller.
http://www.derale.com/installation-i...nstruction.pdf
In my system the blue wire goes to a light not to a fan. The ignition source is wired into a relay that has the circuit closed when the relay is not energised. When I flip the switch the power opens the circuit at the relay and turns off the ignition source to the fans and that turns them off.
Regards
Jean Marc Chartier
