My E-fan Build. with pics.
Old Nov 5, 2008 | 04:58 PM
  #61
97f150xl11's Avatar
Now we are getting somewhere. Thanks to you guys with the same fan replying with your experience.
To fill in a little more I did use 10ga wire and soldered all connections. The switch turns on at 185 and off at 175. Your right it probably should be higher. I will try the wire harness that you guys suggested. The FK35. Didn't want to spend more money but do want it done right. Thanks again.
Old Nov 5, 2008 | 08:34 PM
  #62
Fifty150's Avatar
no this wiring came with no instructions and an ebayer who wont respond back
Ah, no product support. I guess that's another e-Bay lesson learned.
The wiring does have a 30amp relay and an in line fuse so I am not to worried.
With that 30 amp relay, a 30 amp fuse should be fine.
195 is a much better temp to set that fan to turn on. Even if the fan turns on at 195, your temps can easily go up to 200 or more before they start going back down. It all depends on your ambient temperature, and operating conditions.
Old Nov 11, 2008 | 03:29 PM
  #63
FRod's Avatar
Originally Posted by xxs0ulxx
i bought myprobe and controller at autozone. it was only $17.99 its called radiation teperature control (switch?) i think....
are you sure that is what its called, i went to a local autozone and they have no clue what i was even talking about. CAN YOU GET ME A PART NUMBER PLEASE? that would be sweet...
Old Nov 11, 2008 | 03:32 PM
  #64
FRod's Avatar
can anyone send me a link to a website that i can buy this from?
Old Nov 16, 2008 | 01:38 PM
  #65
xxs0ulxx's Avatar
Auto Zone. Brand is TorqFlow. Part number is 733647
Advance auto prats... Part Number: 226203
Old Nov 16, 2008 | 04:37 PM
  #66
FRod's Avatar
your the man! i appriciate it
Old Nov 17, 2008 | 10:14 AM
  #67
xxs0ulxx's Avatar
no prob bro. hope your sucessful
Old Nov 17, 2008 | 02:30 PM
  #68
FRod's Avatar
So i picked it up from AutoZone (greatly appriciated) and it has 2 fan control wires coming off the tempature controller, is that for dual fans? Because i noticed you tied yours together and assumed that you only used 1 of the wires or it only came with one?
Old Nov 19, 2008 | 06:30 PM
  #69
xxs0ulxx's Avatar
so look here you can see the wire im using is the wire that came with it.. and off to my right is another thing of wire, is this what you mean? i used one wire only because i just wanted both the fans to run when the temperature got too hot. Now some guys like to have one on a temp controlr and the other fan on a switch inside the truck. i guess thats what the extra wire could be used for... is that what you meANT?
Old Nov 19, 2008 | 06:32 PM
  #70
xxs0ulxx's Avatar
how do i delete this messege? i cant seem to figure it out in the EDIT function.
Old Nov 19, 2008 | 06:34 PM
  #71
xxs0ulxx's Avatar
The picture above is of the temperature control switch that i mounted next to the wind sheild wiper fluid resevour (cant spell) Below the picture is of the temperature control sensor i put on the radiatior.
do you mean the 2 wires that are shown coming off my controler?
Old Nov 19, 2008 | 10:54 PM
  #72
FRod's Avatar
instructions say fan 1 and fan 2 sooo...your saying ppl wire 1 to a switch and double up the fans on the other...
Old Nov 19, 2008 | 11:52 PM
  #73
Fifty150's Avatar
Fan 1 & Fan 2 should be for the different fans. You should have 1 wire going to each fan. They will turn on simultaneously, when triggered by the temperature probe. This is the same switch type that comes with the Troyer Performance kit.
From my experience, with the Troyer supplied switches, they can fail. If you have both fans on the same switch, then when that switch fails, you have no fans at all. With one switch for each fan, if one fails, the other fan is still working. Even if the switch itself does not fail, the fuse can blow; leaving you with two disabled fans.
With the Troyer Performance kit, the second fan wire is used to power a user supplied LED light mounted to your dash. This light will come on whenever the fan turns on. A little more work, but worth it, if you want to monitor when your fans are turning on. If one fan isn't turning on, you'll also know because the light isn't on. If you don't want to use it, simply tape it off and tuck it out of the way.
Old Nov 19, 2008 | 11:56 PM
  #74
Fifty150's Avatar
PS....In the Troyer Performance kit, the second fan is not powered by the same controller because of high current draw. Depending on how much current your fans draw, you may have the same issue.
Old Nov 20, 2008 | 12:11 AM
  #75
FRod's Avatar
so what do you think i should do? I like the light idea i think i can pick one up somewhere, all i have to do as run it to the light as power, then ground the light right? Than what do i do with the second fan, how does that get hooked up?
