Engine Replacement Costs
Old May 24, 2008 | 10:26 PM
kc chief's Avatar
I have the opportunity to buy a 2001 supercrew with a bad 5.4 motor for very very cheap. My question is how much would it cost to have a new motor installed? It is a 2wd. If you guys have an idea about rebuild vs. crate motor, and labor, I would appreciate it.
Thanks!
Old May 24, 2008 | 10:56 PM
Bent6's Avatar
25 Year Member
Modulars tend to be expensive. I'd say a used engine would be $2000 minimum and a new rebuilt would be $4000 minimum. If you plan getting a genuine Ford replacement, it will be significantly more.
Old May 24, 2008 | 11:09 PM
Wildpilot's Avatar
I just had a Reman 5.4 ltr dropped in my 2000 f-150 this week at the dealer and it cost 5700 after taxes the quote was 5500. a little mom and pop shop quoted me over 6k so i went with the dealer.
Old May 24, 2008 | 11:22 PM
patrickh5116's Avatar
I got a "semi-used" engine for my previous F150 at a junk yard for $700... lets just say that there is a reason why her name was Christine.
Old May 25, 2008 | 12:50 AM
Wildpilot's Avatar
You got a great price on that engine... I called greenleaf auto parts and they wanted to charge me 2100 for a used engine, with no idea what the mileage was. I decided to go ahead and get a new one.
Old May 25, 2008 | 08:11 AM
lowflyingbird's Avatar
Where are you located, I have a Ford rebuilt 2005
I have a 2003 castings, March 2005 factory Ford rebuild motor. I bought it along with other motor from a dismantle yard I do some business with. They were obviously not aware that it was as new as it was or a Ford rebuild I guess. I found the metal rebuild tag on the driver side block. I'm selling it, it is a 2 valve 5.4l. I figure it has about a years run time on it, and it was pulled from a wrecked vehicle as noted in his computer.
Email me if your interested,
ksilibovsky@hotmail.com
Lowflyingbird
Old May 25, 2008 | 08:58 AM
I did, but I got it from a U-pull-it place here in El Paso, pretty much the F150 capitol of the world. Seems like everybody drives one here, so parts can be pretty cheap. It was probably a good call to get the new one given that with a used one, you really don't know what you're getting. An up front cost is always better that getting nickel and dimed to death replacing part after part.
Old May 25, 2008 | 09:44 AM
SCOTTE`screw's Avatar
http://www.rhinoengines.com/ford54engines.htm
i would look around..or look online...you can get cheaper than 5700$$$...thats just crazy....5700 i could get a built motor...
Old May 25, 2008 | 08:41 PM
Wildpilot's Avatar
5700 was total cost of engine, removal and replacement.. from the dealer, i thought it was high also until the little maintenance shop quoted over 6 grand.
Old May 25, 2008 | 10:00 PM
NYTrader's Avatar
I'm just wondering... I checked the value of my 2000 5.4 4x4 auto the other day, 104k miles, average condition.. said it was worth like $6000... What is the thought process that you go through when deciding to spend $6k on a new engine in a vehicle that all together is only worth 6k? I'm not criticizing, i'm honestly wondering what other factors play in that i'm not thinking about..
Old May 25, 2008 | 10:46 PM
Wildpilot's Avatar
Cool
Yes, I definately took that in consideration.. I could have spent that on another used vehicle, and purchased something that I had no clue how it was maintained. I am an aircraft mechanic, the only other times it has been to the shop was for new tire replacement, rotate and balance, and alighnments. I have done all the other work myself. I have life time warranty on virtually all the parts I have replaced, I.E. ball joints, shocks, brake pads, even my rotors are lifetime,I even have a lifetime alighnment on the truck...The tires are not even a month old, spent over 500 bucks on those. Owning the vehicle since new, I know everything else is in good mechanical working order. Plus, I really do not want another truck payment and buy a new one. And, last of all look up the price of your truck with 5000 miles on it. It is considerably higher, a remanufactured engine installed by the dealer definately rose the resell value of my truck, even though I have no intentions on selling it. A vehicle is not an investment, I consider it more of an expence. So with all the factors considered, I feel it was less of an expence to have a long block installed and keep on trckin'. Good question though
