minimum CFM for E-fans
Old May 21, 2008 | 09:18 PM
Blown F-150's Avatar
I have a 2000 with a 5.4. want to put in E-fan kit. I found a flex-a-lite kit model #220. it's a low-profile kit that I might work well with trying to fit my intercooler piping. I am just worried about its puuling power, its rated for 2500CFM. Do you think it's enough?
Old May 21, 2008 | 10:15 PM
NYfordguy's Avatar
My ONE fan is rated for 2500, both are 5000cfm. So......
Yes, one fan is enough to cool the truck, but when your are moving slow with no airflow over the radiator, one may not cut it.
Old May 21, 2008 | 10:25 PM
StrangeRanger's Avatar
That's WAY too small. It's primarily designed as a booster fan to add cooling to an overloaded system which retains the stock fan. For a stand-alone you should be looking at something like the FAL 270 rated at 5500 CFM
Old May 21, 2008 | 11:11 PM
yeah I found a kit for $160, so I figured I would pick them up, but looking into it they are only 12 inch fans, when I originally thought they were 15 inch.
the 270 kit looks like the right fit, guess I just keep saving pennies for now. so all in all we should get a min of 5000cfm to replace the existing belt driven fan right?
Old May 21, 2008 | 11:14 PM
built54's Avatar
i wouldnt want less than 4000cfm total...
Old May 21, 2008 | 11:19 PM
Fifty150's Avatar
The Troyer Performance Fan Kit uses 2 fans that are rated @ 2775 CFM.
Old May 22, 2008 | 12:42 AM
lenore's Avatar
or use this Lincoln fan (Mark VIII or thunderbird) seimens 18 inch fans, it moves 4300 cfm and can be found in any u pull it junk yard for $29... Then add this controller which has all of the wiring and hookups...:
http://www.dccontrol.com/0820.htm
total cost $167
Look at my efans under my photos....
Old May 22, 2008 | 01:07 AM
Looks like a nice set up, I will go to the wreckers on the weekend and see if they have anything. I wasn't going to go that route because of the need for a controller. but the link provided looks like a nice controller. I was thinking of a simplified method of activating it using a thermo switch on one of my old polaris quads, and having it on the low amprage side of a solenoid activating it and have the fan power on the other side, if I remember correctly it turns on at 170 celcius. then have a switch if you want it on all the time. the bonus being that the thermo switch screw right into the drain bung.
Old May 22, 2008 | 01:17 AM
I like the Troyer kit, but I heard of a few with electrical fires and such, possibly the way they were installed I guess, I also didn't like the idea of running rods through my rad. I think that has changed now, but I'm not sure.
It would probably be about $550 landed by the time it got to Canada.
Old May 22, 2008 | 10:36 AM
lenore's Avatar
You would be cheaper with the DCcontrols kit. And the fan is soft started to eliminate currant spikes....
Old May 22, 2008 | 10:57 AM
malexander52's Avatar
Wow!
total cost $167
That looks really sharp! Which controller did you get, FK35,50,60, etc....?
Did the Lincoln fan come with the shroud? Again that looks really good.
Old May 22, 2008 | 11:04 AM
ELVATO's Avatar
Yea a comes with a shroud. I should have a pic somewhere....
I got the FK50P, though you should be OK with the FK35.
Old May 22, 2008 | 11:07 AM
JMC's Avatar
JMC
25 Year Member
I am using the Troyer kit with my own mounts.
I also did some creative "plumbing" and routed the pipes between the frame and the body. So when I go off road the pipes will not get smashed. If I remember correctly I used the elbows from the driver side on the passenger side and had to cut a couple of the longer pipes. I should take pictures....
Regards
Jean Marc Chartier
Old May 22, 2008 | 03:31 PM
mitch150's Avatar
Regards
Jean Marc Chartier
Pipes? Please slpain yourself lucy(just kidding) What pipes are you speaking of?
Old May 22, 2008 | 04:08 PM
Fifty150's Avatar
The Lincoln kit is one fan at 4300 CFM.
The Troyer kit is two fans at 2775 CFM each, totaling 5550 CFM when both fans are on.
I have also heard that the Troyer kit is more expensive. However, I bought them anyway and I'm quite happy with the product.
I haven't heard anything about electrical fires. It's hard to say. Some fires are caused by bad parts. Other fires are caused by incompetent installations. The logic being that if all of Troyer's kits had faulty parts and/or design, then we would all have had fires.
