Truck wont crank. Fuel pump?
Truck has never had any trouble starting at all and we parked at a store and everything was fine. Came back out to the truck and it wont start. It turns over fine just wont start. I did the best i could do in the parking lot but i dont think i could hear the pump come one. Do they just go out this easy with no warnings? The truck is a 99 5.4 F150
on
"Cranking" means the starter is engaging and the engine's crankshaft is being turned properly by the starter
"Cranks but does not fire" describes that exact condition which may be caused by a loss of fuel supply, spark, or no air.
Listen very carefully for the fuel pump to turn on for about two seconds when the ignition switch first is turned to RUN from OFF. Remove the fuel cap and listen at the fuel filler if needed. If the pump is not running, check the inertia switch and the fuel pump fuse. Also check to see if the CEL is turning on properly during that first two second interval.
Steve
Prolly a fuse or the relay, that's what you check first if the pump doesn't run in the "KEY ON" position.
The 99's used PATS I believe? I think that's the first year for those, but if she cranks , that's most likely not the problem.
Hold the pedal on the floor as well , but don't crank more than 5 seconds or you'll shut the injectors down.
Determine the pump is running first - that was mentioned above along with the other good info already posted and go from there.
Heres a little chart that may help if you have trouble figuring it out -
Similar-Won't start odometer reads dashes theft light flashing
I have a similar thing. My 2000 F-150 5.4 won't start, odometer is reading dashes "-----" and the theft light is flashing. It was intermittently stalling & not starting for a few weeks and got progressively worse. At this point it was just not starting, I didn't have the odometer problem or the theft light. I replaced the Fuel Pump Relay (no help) then the PCM relay (no help) then I changed the fuel pump, and the odometer thing and the flashing light started. Also it occasionally just has the windshield wipers come on once or twice out of nowhere. I talked to a friend at a dealership and he thinks that my Key has dropped its code or the PATS module has died. I can't afford to replace either yet but when I do I'll let you know if this works. I saw some posts with this very specific combo of things on some other forums, but no one has a solid fix that I have seen. If any of you have anything I would appreciate it.
Thanks,
Jim Stackable
Thanks,
Jim Stackable
First off u have to find out if the pump is working like every one else says, then if it does not turn on check the relay for it and the fuse. If both are ok i would suspect the fuel pump being bad. If u hear it turn on but she still doesn't fire check the fuel pressure it could be so low its not making it all the way up to the injectors and yes, fuel pumps can go out with out warning but usually the start of a failing pump would be hard starting or misfire at intense throttle.
Sorry so late i fixed it. Took me one and a half hours to drop the tank and replace it. I would of pulled the bed but i was the only one working on it. When i got back to the truck this morning it fired right up and ran. I turn it off and wouldn't crank. So i towed it one block on base to the shop and fixed it there. So i said let me try a old school trick and kick the **** out ofthe tank and she cranked right up LOL turned it off and wouldn't crank. The fuel pump was 99$ and the Fuel Pump Strainer was $19.99 i got it for $110.00 military discount. So $110 for fuel pump and 1.5 hour install isn't bad. i cant imagine what a shop would charge for something so easy. I have change alot of fuel pumps on GM/mopar cars/truck this was my 1st ford and i must say i like the way it bolts up to the tank instead ofthe other way they do alot of them. Thanx alot
Nice job getting that done, I think dropping the tank from below is easier than removing the bed myself, but I might have a "slight" advantage with available tools and equipment
"Nice job getting that done, I think dropping the tank from below is easier than removing the bed myself, but I might have a "slight" advantage with available tools and equipment."
True that. Flat on your back is a disadvantage in this situation.
And if you have half a tank, or more, of fuel...............
