Gas tank in place of spare tire??
  #61
Old 01-20-2011, 04:27 PM
Klitch's Avatar
Originally Posted by shifty_85
yeah for a while i was looking for my buddy to weld me up a huge take in the back of my bed but i scraped that idea.
i know im gonna get flamed for this but i really dont know the diff between lets say a 10gal fuel cell and a 10 gal gas tank???
From my understanding, cell was just the same as tank, except it has a bladder that way you have some protection against spillage. Say if the outer shell is punctured, perhaps the cell (bladder) would not be.
  #62
Old 01-21-2011, 02:54 AM
shifty_85's Avatar
any one know how i can get around the OHM issue between sending units?
  #63
Old 01-21-2011, 03:19 AM
Klitch's Avatar
steal ur old one and mount it up?
  #64
Old 01-21-2011, 05:06 AM
shifty_85's Avatar
my old one is only a 20 or 25 gal my new tank is 33 gallon.
  #65
Old 01-21-2011, 02:29 PM
Klitch's Avatar
I meant more like use the plastic sender its self, I believe you can remove the float arm from it and use the one from the 33 gallon tank so the range of swing will be for the tank, but the sending unit will work with your gauge. thats my thought process.
  #66
Old 01-21-2011, 02:37 PM
freekyFX4's Avatar
That tank would make a great addition for someone planning on driving the Alaskan highway.
  #67
Old 01-21-2011, 04:11 PM
shifty_85's Avatar
i see what your saying klitch. well im not gonna rip into it untill i have the sending unit the fuel pump the breather and an idea for straps.
  #68
Old 03-10-2011, 10:00 AM
shifty_85's Avatar
does anyone know the fuel line size on my truck? the inlet line and the return line?
im going to buy steel fuel line because the rubber is 16 bucks a foot for fuel injection hose.
also theres a sweet shop called "Jeffsbroncograveyard some of you may know the site just add .com to that. im going to take that 33 gallon take there and get a sending unit that fits and a breather and maybe an inline pump.
Where should i mount the pump? im thinking driver side frame rail right were my old tank used to be that way i dont have to run any wires for the pump.
if someone could get me a wiring digram of the fuel sytem for the pump sending unit that would be awesome i have a haynes book but i dont know were it is now.
should be getting income tax money back its going to happen this time i cant stand seeing my tips sit in box's any more!!!!
  #69
Old 03-11-2011, 12:35 AM
madferraristi's Avatar
I used a floatless sender from this company: http://www.centroidproducts.com/ when I put my tank back there.
They make it to suit the depth of your tank, all you have to do is install it into the top, hook it up and you're good to go. They're not expensive.
  #70
Old 03-11-2011, 12:28 PM
shifty_85's Avatar
that looks neat.
Anyone know the line sizes so i can get some steel line?
  #71
Old 03-11-2011, 05:29 PM
that looks neat.
It's been five years since I replaced them, but IIRC, the supply line was 5/16" and the return 1/4".
  #72
Old 03-11-2011, 10:43 PM
shifty_85's Avatar
Thanks. ill double check when i get down there to make sure.
well short of the sending unit this wont be hard and if i have to ill just get a colum pod with a gas gauge.
  #73
Old 03-12-2011, 11:48 AM
The Centroid Sender works with the OE Gauge, just be sure to tell them you have an F-150 and that you want the "old" type that responds instantly after fillup.
  #74
Old 03-12-2011, 12:27 PM
shifty_85's Avatar
How much do those go for?
  #75
Old 03-13-2011, 12:43 PM
IIRC, about $60.00.
Quick Reply: Gas tank in place of spare tire??
