Champion Develops "FIX" Plug for 5.4L 3 valves!
Old Mar 5, 2008 | 05:33 AM
  #166
tech-doc's Avatar
Originally Posted by ryan42680
2 questions about the plug issues. First oneis I have a 60k mile powertrain warranty. If I take the truck in before 60k to have plugs changed and the service department breaks them on removal, is it on them to replace it at their cost? I'm pretty sure the plugs themselves aren't covered in the warranty if they break, but if it involves pulling heads and running a huge bill, would that be warranty work? I would hope so, especially if the service tech broke the plug in the head...
Second question is if I were to wait to 100k miles and took it to the dealer to change the plugs and a plug broke, would that be on the dealer to replace/ repair whatever issues arise from the broken plug despite being out of warranty? If you take it to the dealer for the recommended maintenance at the recommended interval and they break something (and the vehicle is no longer on warranty) is it still on them to fix it at their cost? I would hope this would be the case as well, as in either case the dealer was the one perfoming the service and breaking the plug in the cylinder head.
I just hear alot about guys paying out their a$$es to pull the heads and repair the problem from broken plugs. Is this usually cause they are replacing plugs on their won so it is on them to pay if they break something?
If you are under warranty, and *IF the plugs fail*, your warranty DOES cover it. On the other hand, you REQUEST them changed and they break, YOU FOOT THE BILL.
When you go in with a misfire, the stealership will only replace that one failed plug.
Old Mar 5, 2008 | 05:36 AM
  #167
tech-doc's Avatar
Originally Posted by 150_Eagle48
I live in Gldsboro NC the dealer here deacon jones very big Ford Dealer.The service tech said they always break some on every change but have not done many because most people do not have that many miles on their trucks.Here is his cost 280. pus tax to change 8 plugs and for eveyone they break off they charge an extra 2 hours labor at 60 dollars an hour thats alot of money.If he has to removed the head he does it at the hourly rate after the 280.
So, in other words, they are getting paid twice for the same job. The TSB tells them to claim actual time to Ford. AND, they are charging YOU for the same time they are claiming to FORD.
TRIP TO DISNEY LAND ANYONE?
Old Mar 5, 2008 | 06:37 AM
  #168
FordTech1's Avatar
I wonder where they get the 2 hours/broken plug?? Fordtech1, what's the book say for the number of hours to remove a head??? My guess is 4-6.
Warranty pays 5.3 for the left side, 5.4 for the right or 6.4 hours for both (head removal that is)....
2hours per plug removed does seem high...and it does state to claim actual time on the bulletin which means "DO NOT PAD the job" HOWEVER those little Ford videos always show how things work in a perfect world, doesn't always go that way. I've never really had to remove them with the tool so I can't give an honest opinion if that's a fair amount of time. Personally I think they are trying to cusion their time if one does go wrong, it will happen.....maybe just a bit too much cusioning...Someone posted not too long ago about getting some stuck plugs out I thought....maybe they could provide some input.
Old Mar 5, 2008 | 08:40 AM
  #169
dkstone05's Avatar
It depends on the dealer. Seems most are passing the bill off to the customer if they break during removal even if it is under warranty. However the service manger I spoke to said while the truck is under warranty I would not have to pay a penny more. He said Ford is trying to take care of their customers in hopes of getting repeat business. He reassured me that he would go to bat and get Ford to pay for the extra work if anything did happen. It almost seemed like he has been through this before. I will find out as soon as the Champion plugs I have on order come in. Hopefully there will not be any problems, I'm at 33,500 miles now and have always used quality gas.
My advice would be go into the dealer and ask to speak with service manager. Don't be an asshat, just let him know that you know all about this potential problem and would like to discuss it with him. What ever you do, don't talk to a service writer about it. The first one I spoke to said this problem was for the pre- 2004 trucks. I tried to tell the guy he was wrong but he got all defensive and said " I own one of these truck, I would know if it had a problem". So I that point I just let it go and the next time I went in I just asked to speak with the manager and we ended up having a nice conversation about the issue.
Old Mar 5, 2008 | 04:54 PM
  #170
ryan42680's Avatar
Well I guess the answers here lead me to my next Q, does this problem apply to later models ike my '08, or is it more '04 to '06? I know the plug itself is a bit different with a higher cut on the shield, exposing more of the electrode causing it to burn hotter, but does this also fix the problem of shields separating and sticking? And are they now using anti sieze on the plugs? The problem I see is that they can say they fixed the problem, but how many '08s, or even '07s have 100k miles on them and are going for plug changes now? I would say very VERY few, if ANY. So we '07/'08 owners don't really even know and won't for some time...
Old Mar 6, 2008 | 04:25 AM
  #171
tech-doc's Avatar
This problem applies to the 5.4 3V. If you have one, your a$$ is in the fire as well.
No, the 07/08 owners will not know if their plugs are going to stick as of yet. BUT, we do know that there is a plug problem and Ford has not redesigned the head, only speced a hotter plug.
Save yourself a little heartache and put a 1 piece plug in NOW! That is the ADVANTAGE the 07/08 owners have. Keep the monkey off your back from the get go.
Use the motorctaft plugs as christmas ornaments!
Old Mar 6, 2008 | 09:25 AM
  #172
Here is my success story as of yesterday.
https://www.f150online.com/forums/sh...d.php?t=324137
Old Mar 6, 2008 | 03:57 PM
  #173
ryan42680's Avatar
What you say makes alot of sense...as an '08 owner, I will not know if the non-problem problem was resolved, even though I have seen several threads where owners say the dealer told them the issue that was not an issue was fixed, so in other words, Ford just changed the plug design in '07 for the hell of it, not to correct a problem they won't own up to. Confusing, isn't it!!! However, as I mentioned, I have read through several threads where supposedly the issue was corrected by using a slightly modified plug which has a higher cut to the shield, allowing a higher temp, which supposedly burns off more carbon, but who really knows. I want to change to a one piece like the Champion plug, but I want more feedback on it first. It is new to the market, and I don't want to put in a new designed product that for all we know is worse than the OEM (I'm sure it's not, but who knows for sure). I'm only at 9k right now, so I have plenty of time before I make the switch, I just want more info.
On a side note, can we as owners purchase the Rotunda tool from a dealer or elsewhere? After watching the tech vid, episode 26, it seems like a relatively painless process, just a little time involved. If I suffer in the future from this broken plug syndrome, I would want to fix it myself with a half a days worth of garage time, rather than pay the dealer out the a$$ to fix it while I sit there sipping the Green Mountain coffee and watching the Tyra Banks show in the customer service waiting area for several hours...no plug intended. Wait, I just made another funny and didn't even realize it..."plug"! HAHAHAHA!!!
Sorry, long day at work...
Old Mar 6, 2008 | 11:53 PM
  #174
hillbilly4u's Avatar
I've worked Dodges, Chevys and Fords. This truck I have now will out do any of the others I've had. We have 12% grades here where I live and just today I had 3/4 ton in the bed and towing an 18 ft trailer loaded. 60 mph up a 2 mile long mountain was no problem at all. The Chevys & Dodges can get me from take off but put some weight on their $ss and I'll smoke'em. It pains me deeply that a truck like this could have this stupid little plug problem. But we don't live in a perfect world by far. As for me I'm gonna keep on Truckin!! Somebodys gonna eventually figure this crap out even if Ford won't.
Old Mar 7, 2008 | 05:48 AM
  #175
risupercrewman's Avatar
Old Mar 7, 2008 | 06:16 AM
  #176
FordTech1's Avatar
Not quite, see my previous post
No design change in the plug, just hotter to address driveability issues and I think the engineers are hoping it will solve the sticking problem but they are not wanting to call it fixed just yet....It wold be a little premature for them to call that one don't you think....imagine what would happen if they did come out and say "it's all fixed" and then a year down the road it starts happening again.....The dealer only knows what Ford tells them and they haven't said anything official. My info came from their technical hotline, that's about as good as it gets at the dealership level.
It's frustrating trust me, as a Tech and an F-150 owner. My plugs are coming out next week (23,000 miles), at least I know they guy doing the job
Old Mar 7, 2008 | 01:27 PM
  #177
bamorris2's Avatar
I don't know if this would qualify as a "change", but as you can see from the pics, the shield on the PZT-14F is cut higher than either the 2F or 1F.
Old Mar 7, 2008 | 01:50 PM
  #178
FordTech1's Avatar
yup, I got a set right here...the PZT-14F's that is.....the tip is unshrouded more to let the plug run hotter.....not really a design change, just a diffrent heat range.
Old Mar 7, 2008 | 02:44 PM
  #179
bamorris2's Avatar
That's the same thing I thought at first... But as I understand the heat ranges of the MC plusgs, they go like this, in order of hottest to coldest:
PZT-2F
PZT-14F
PZT-1F
So if that's the case, then why does only the 14F's have the shield cut higher? The 2F and 1F look exactly the same. So if the theory is that the 14F's shield is cut higher to allow for a hotter running plug, then wouldn't the 2F's shield be cut even higher than the 14F?
I just think there's gotta be more to it, but I don't know what it is...
Old Mar 7, 2008 | 02:50 PM
  #180
My dealer installed the 1F in my truck.
