water in oil????? help!!
Hey guys, I just changed my oil/filter and when i took the oil cap off the valve cover to fill oil there was a bunch of white slimy stuff....moisture?? I've never seen it before. Then, when I drained the oil it looked a little different than usual...maybe a little milky?? I religeously change the oil every 3 months so it hasnt been in there very long. Any idea what is going on? Should I have the oil analyzed to see if there is anything like antifreeze in there?? just a little concerned.
oh ya and also, ever since I got the truck about a year ago I always put 6 qts of oil in but only get a little more than 5 quarts out. I know some of that stays in the filter but wheres the rest. The 5.4 only has 65k on it, there are no leaks underneath and it doesnt seem to burn any that i can tell.
thanks for all your help!
did you check the oil level before you drained it?
you stated you only get five out so i guess you know how much came out.
is there any coolant mising?
it don't take much water to make it milky though.
keep poking around the engine looking for other clues. getting in a hurry is where you will lose money
does it look like this?
then im going to guess its normal. I even had my head gaskets changed, pressure tested the heads etc... unless the machine shop ied to me i dont have a problem. i drive short trips myself, despite letting the engine warm up for 10-15 mins before leaving i have the same problem. the reason is the filler neck never really heats up and the oil splashes right up there. there is a cam lobe and rocker arm directly below the neck, oil splashes off them into the tube, because it remains cold you get the slime. if you change your oil and it looks slimy coming out of the pan then you got a problem, otherwise its probibaly fine. Just wipe it out every so often.
Pheonixx, those near 30 meg pictures will kill anyone who has dialup. I'd suggest fixing them...
pic 2 is 28 KB
(right click them and go to properties...)
a megabyte is 1 million bytes and a kilobyte is 100,000 bytes.
30 megabytes would be 30 million bytes or 300,000 kilobytes.
the largest pic is 1 MB
but thanks for the concern. now back to your regularly scheduled topic
Originally Posted by Pheonixx
pic 1 is 161KB
pic 2 is 28 KB
pic 2 is 28 KB
Well , you could thumbnail #1 to be considerate + it's blury ..
Wouldn't hurt
pic 1 is 161KB
pic 2 is 28 KB
pic 2 is 28 KB
LMFAO!
youre right jbrew pic one was pretty craptastic, i just posted a new one. my camera has a macro option for closeups but it somehow still sucks at taking closeups.
Mine does that sometimes, I don't know what the deal is. I reset the camera to default and it does alright for awhile - until one of the kids get ahold of it
Much better pic though - It would suck to have dial up. I didn't think anyone had that anymore..I guess that would be your only choice if you were out in BFE without cable or a WiFi server..
