just cleaned MAF sensor...
Old Nov 13, 2007 | 09:49 PM
full_tilt's Avatar
just cleaned mass air flow sensor for first time in 85K miles
the tutorial on this board made it easy... Thanks!!!
the MAF sensor on a 1999 F150 looked a little different then the picture in the tech article... there was a long plastic sleeve covering the MAF which I didn't remove... just sprayed up in the little SOB real good
noticed there's another sensor a little farther up moving towards the engine... what is this one and does it ever need cleaning
Old Nov 13, 2007 | 09:54 PM
MGDfan's Avatar
Good job.
That other thang be the IAT ( intake air temp) sensor - you can clean it if you wish; I would not use MAF cleaner on it, just a gentle bit of canned compressed air.
BTW - what all else ya done / plan to do at this mileage?
MGD
Old Nov 13, 2007 | 10:08 PM
NYfordguy's Avatar
Did you notice any difference in engine performance?
Old Nov 13, 2007 | 10:25 PM
jbrew's Avatar
This guy just did - https://www.f150online.com/forums/sh...d.php?t=308294
I've seen quite a few on this site notice a significant difference in performance. When the MAF's dirty the PCM doesn't cipher right. Anything in the "Air Metering" department that is less whole can effect the way she runs.
Personally I never witnessed the effect myself , I don't think that I have gave it enough time to get dirty before cleaning. - Kind of a fanatic about keeping things at there best
I notice a big gainer when I changed out my COP's tho - like night and day Mann, my truck runs good ( :
Old Nov 13, 2007 | 10:46 PM
NYfordguy's Avatar
True about ign. components, i swapped out my OEM 97 coil packs for the accels from troyer, wow what a difference.
Old Nov 14, 2007 | 02:04 AM
Can you effectively clean the MAF without removing it from the intake tube - i.e. just spray the hell out of what you can see after opening the air cleaner?
Old Nov 14, 2007 | 02:21 AM
jbrew's Avatar
I don't see why not. I take everything apart myself .. I really don't like the idea of doing it that way with all the plastic around. BUT , you could prolly get away with it..
Old Nov 14, 2007 | 01:53 PM
Well, I believe MAF cleaner is essentially no-residue electrical contact cleaner, which SHOULD be plastic-safe.
Old Nov 14, 2007 | 03:43 PM
4wd150's Avatar
can somebody give m the link to the MAF tech article i am wanting to do it hasnt been done in 100k miles
bought the crc stuff but havent got at it it yet
Old Nov 14, 2007 | 04:21 PM
MGDfan's Avatar
Well, 'Senior Member', you should try searching for this stuff - you know it's often discussed.
In fact, I think you need to demonstrate you can, to preserve your 'Senior' status
Here ya go - don't let it happen again ....
It's in this thread - I ain't gonna spoonfeed ya lol
BTW - 'please' and 'thank-you' are in the english vernacular - just an fyi next time you ask for help.
https://www.f150online.com/forums/sh...d.php?t=307880
MGD
Old Nov 14, 2007 | 04:28 PM
I just bought a can of CRC MAF cleaner over at O'Reilly's - it says right on it that it's plastic safe.
Old Nov 14, 2007 | 04:39 PM
4wd150's Avatar
MGD
my bad
thanks
Old Nov 14, 2007 | 10:02 PM
willow92's Avatar
Hi Guys,
i am fairly new on the forums,i must admit i read alot more than i write.
anyhoo iam fairly **** about keeping my engine bay clean,but this weekend i followed the instructions on cleaning the maf sensor along with the rest of the air intake system.
i was amazed at the difference this one little sensor could make to the performance of my truck.
in my opinion even if you think your truck runs great you still need to attempt this.
Old Nov 14, 2007 | 11:01 PM
squirtbottle09's Avatar
Just got done with mine and noticed a performance upgrade as well. Hopefully that was causing my CEL
Old Nov 15, 2007 | 03:02 PM
jbrew's Avatar
That cool , you can prolly hit the IAT with a shot as well
AND - the IAC toooooo - Shoot just spray into the intake at about 3000 Rpms and get all three sensors at the same time
Yea , I wish I t worked that way .. Good Stuff!!
Hmm, I wonder if that's a 4-10 HP gainer per sensor cleaned - Yuh Think!!
