Running rich
Old Nov 12, 2007 | 02:46 PM
  #46
or retarded timing
No, advanced timing causes spark knock - i.e. it's all fired off before the piston reaches TDC. Higher octane fuel burns slower.
Old Nov 12, 2007 | 03:10 PM
  #47
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
Octane is added for premature detentation from the fuel being compressed. Igniting before the spark is sent.
If you advance the timing the spark is what it igniting the fuel, which is wha tis suppose to happen, when it's advanced, then the piston is lower in the cycle so the A/F is under less pressure. Adding octane will not help that. In that case the fuel is being ignited by the spark like it's suppose to when the ignition tells it to, not from the fuel being compressed. If timing is advanced, then you can add all the octane you want and all you'll do is lose power and MPG, and stiil have your problem.
It's not any slower burning it burns at the same rate, and it's not any hotter or colder. It just wont ignite from being compressed as easily.
Old Nov 12, 2007 | 03:14 PM
  #48
PSS-Mag's Avatar
Originally Posted by jbrew
Cop 5 is right up front - that should of been easy - I think it's a 7mm bolt .. Yea , when there stripped it slows things down a bit
My door locks quit working once . Couldn't figure it out , they both quit working at the same time .. A week or two went by and I worked on something else under the hood and had to reboot the computer after .
Well , The Power windows have been working great since .. - The computer was just buggy
Sometimes just zapping the parameters (PRAM) will straighten her up..
If you want to TEMP fix your manifold - High heat Gold W/Copper , made by Permatex will seal between the manifold and head . It has a 700 degree rating and your only @ 250 - 300 degrees in that area. It only 5 bucks and that chit is awesome..
Good Luck
Yea the head rounded 7 mm slipped and couldn;t get a 6.5 mm on it. It was siezed inside the COP bushing too.... I was going to just glue the cop back together and use it, but I couldn;t get the brass bushing for teh cop off the bolt. That one was a PIA, the others came right out no problems.
Old Nov 12, 2007 | 03:45 PM
  #49
Zaairman's Avatar
Originally Posted by PSS-Mag
ETA:
I was going to tackle the drivers side and maybe passenger side door lock actuators tomarrow.
Wonder whats the chances of getting the manifold and locks fixed.....
How'd the door locks turn out?
Old Nov 12, 2007 | 03:50 PM
  #50
PSS-Mag's Avatar
It rained today so decided to use teh time to do some work for teh office and make some money instead. Tomarrow will eba short day out, so should be abck home by early morning. Might try then if it's not raining.
Gees I need a garage........
Old Nov 12, 2007 | 05:04 PM
  #51
The rain missed us - so far.
Old Nov 12, 2007 | 06:48 PM
  #52
PSS-Mag's Avatar
Didnt me, it was raining when I got up this AM and rained with occasional down pours enough to knock satelite out for a few minutes several times, off and on until about 2 in the afternoon. Then sprinkles off and on since.
